Types of lathe reference
  • Ingo
  • Ingo's Avatar Topic Author
  • Premium Member
  • Premium Member
19 Nov 2021 04:39 #226949 by Ingo
Replied by Ingo on topic Types of lathe reference
Sorry for my ignorance, but what would the carousel component be?
19 Nov 2021 04:49 #226950 by Henk
Replied by Henk on topic Types of lathe reference
It is part of linuxcnc. Called a component. It will not be in your normal pncconf generated Hal file.
In short. You load this piece of software in your Hal file that will provide extra Hal pins that can control your turret.
Open a terminal on your Linuxcnc machine and type man carousel.
Or Google "linuxcnc carousel"
In your Hal file, you load this with loadrt carousel followed by some options.
Add it to an update thread with addf   servo-thread.
Henk
  • Ingo
  • Premium Member
  • Premium Member
19 Nov 2021 04:56 #226951 by Ingo
Ok, i will run these tests.
Thank you very much, I probably bother you more….
  • Ingo
  • Premium Member
  • Premium Member
09 Dec 2021 09:36 #228693 by Ingo
Staff after the help and a lot of persistence I managed to make my turret work….  I didn't use it as a carousel, well in the end I believe the biggest problem was related to the cycle start, abort, resume buttons, that wasn't releasing the M6.
I'm trying to interloock the ladder, for example, my spindle in automatic mode is opening and closing the clamp with it turned on.  I even managed to do it using my physical buttons, but I couldn't do it with the buttons on the Gmoccapy screen.
Time to create page: 0.163 seconds
