Help
- DavedaBuilder1
10 Nov 2021 18:47 #226019
by DavedaBuilder1
Help was created by DavedaBuilder1
Totally new at this Linux, finally got to where I can load on one computer. Now totally confused on how to load LinuxCNC so I can start using my cnc
- Clive S
- Thank you received: 486
10 Nov 2021 19:51 #226031
by Clive S
What did you load on the computer? What version of linuxcnc ?
Can you open a terminal and type uname -a and report back
Replied by Clive S on topic Help
- DavedaBuilder1
29 Nov 2021 15:20 #227909
by DavedaBuilder1
Replied by DavedaBuilder1 on topic Help
I have started over and havent messed with anything since family and Thanksgiving took priority. After posting this thread I went back and have Debian loaded, and after reading Im a little confused on how to try and load LinuxCNC. The way I understand is that I need to be loagged on to my Linux account, is this correct. I did the Debian load from the Microsoft Store and used Virtual Box. I have that actually working now, but now the problem is that I cant seem to connect to the internet to download the LinuxCNC while logged into my Linux account. Before I go into the Linux from the Virtual Box I show that I have a connection. I have tried everything that I understand as to what to do to get a connection but nothing works. Any suggestions
- Thank you received: 7468
29 Nov 2021 16:21 #227921
Replied by tommylight on topic Help
It is not possible to control a machine from LinuxCNC, as far as i know.
Start here:
linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html
Start here:
- Thank you received: 1472
29 Nov 2021 21:26 #227952
Replied by Todd Zuercher on topic Help
It will not work to try to control a machine running Linuxcnc in a virtual machine like Virtualbox. The Linux os for Linuxcnc must be installed on a real PC, because it requires low level control and interaction with the PC's hardware to communicate with the cnc machine's hardware. It is perfectly ok to install Linuxcnc in a virtual machine for simulation purposes, but it will NOT work to try to use that to run an actual machine.
