g33.1 not running whit w axis
11 Nov 2021 19:47 #226134 by papagno-source
g33.1 not running whit w axis was created by papagno-source
HI at all.
If run m3 s100
after g33.1 w-50 k1
the w axis not move.
G33.1 fuction only with x,y and z axis?
I have test g33 w-50k1 and it running
Is bug or normality operation ?
18 Nov 2021 00:07 #226813 by andypugh
Replied by andypugh on topic g33.1 not running whit w axis
Interesting question. I suspect that you need to look at the source, but I suspect that you might find that it is Z axis only.
github.com/LinuxCNC/linuxcnc/blob/master...erp_convert.cc#L4774
Yes, XYZ only.
Might be an easy fix to add UVW. It does feel like there should be at least an error message.
Time to create page: 0.087 seconds
