Probing macro: Cannot complete move after probe contact
- stefan
12 Nov 2021 16:26 #226228
by stefan
Probing macro: Cannot complete move after probe contact was created by stefan
I have a touch plate connected to a MESA pin to zero the Z axis. I initiate probing through a button on the probe, which runs the following macro:
LinuxCNC correctly detects the probe contact and stops, but then the move to raise Z back up gets interrupted, and it only moves up by a fraction of a millimeter, instead of the 20mm. I'm pretty sure it's because the probe input in LinuxCNC goes from "touching" to "not touching" during that move, though I don't get any errors from LinuxCNC.
What am I doing wrong? Of course the touch probe will go from touching to not touching once you back away after the G38.2 command, right?
o<touchprobe> sub
; Configuration
G21 (mm unit)
G91
; Probe Z at slow feed rate.
G38.2 Z-20 F50
; Set Z0 at point where probe triggers with known offset [this is the thickness of my touch plate]
G10 L20 P1 Z21.4
; Raise back up
G90
G0 Z[#5063+20]
o<touchprobe> endsub
M2LinuxCNC correctly detects the probe contact and stops, but then the move to raise Z back up gets interrupted, and it only moves up by a fraction of a millimeter, instead of the 20mm. I'm pretty sure it's because the probe input in LinuxCNC goes from "touching" to "not touching" during that move, though I don't get any errors from LinuxCNC.
- MaHa
- Thank you received: 240
12 Nov 2021 19:54 #226243
by MaHa
Replied by MaHa on topic Probing macro: Cannot complete move after probe contact
You touch off with coordinate system 1
on trigger set coordinate system 1 to Z21.4
at this point #5063 is related to coordinate system 1 BEFORE set Z to Z21.4, not really usable
maybe you can try 38.4 Z1, probe away and then #5063 has the value of the release point and then G0 G90 Z[#5063+20] should work,
or if this fails,
G1 Z1
and probe again G38.2 Z-1.2 , then lift of as tried before
or if this fails,
G1 Z1
- stefan
20 Nov 2021 04:35 #227050
by stefan
Replied by stefan on topic Probing macro: Cannot complete move after probe contact
I've tried both of these suggestions, it's still not working for me. For instance, I've tried this:
The spindle moves down, detects the probe contact, then moves up until the probe releases, but then the program immediately aborts (never reaching the last two lines). Why could that be? Is there a way for me to debug this? I've tried running with `-d -v`, but no useful output is shown. The UI (I've tried qtdragon and gmoccupy) don't show any errors/warnings.
G38.3 Z-20 F50
G4 P2
G38.5 Z10 F50
G4 P2
G10 L20 P1 Z21.4The spindle moves down, detects the probe contact, then moves up until the probe releases, but then the program immediately aborts (never reaching the last two lines). Why could that be? Is there a way for me to debug this? I've tried running with `-d -v`, but no useful output is shown. The UI (I've tried qtdragon and gmoccupy) don't show any errors/warnings.
- stefan
20 Nov 2021 05:17 #227051
by stefan
Interesting observation: the problem only happens when I use my home-made probe that's connecting an aluminium piece to the spindle (which is grounded). When I use a button-based touch probe from aliexpress, it works, so clearly the problem is with my probe.
I'm using a Mesa 7i76e, which expects inputs to be high/24V, so I'm using a pull-up resistor of 10k Ohm, which pulls the input pin low when the spindle/bit contacts my probe. Am I doing something wrong? I've seen the same setup in many other places.
- stefan
20 Nov 2021 18:34 #227111
by stefan
Wow, this is embarrassing, but I'll say what the problem was on the remote chance this helps someone else: I was also setting up a control panel button to stop to program, and accidentally tied the probe input to halui.program.stop (instead of the button input). This means any time the probe released, halui.program.stop was triggered, stopping the probing macro. It all makes sense now
