Mesa 7i76e connection lost
4 years 11 months ago #226316 by roland206
Hi
I run linuxcnc 2.8 and a MESA 7i76e(d) card. So far everthing up and running.
It happens that the ethernet connection gets randomly lost.
The ethernet connection is a 1-by-1 link to the Mesa card.
I tried the default IP and the 10.10.10.10 IP.
I tried the same setup on different computers with similar results.
any idea ?
4 years 11 months ago #226322 by tommylight
4 years 11 months ago #226323 by roland206
Error report: System message
Coonection lost
no longer connected to 802-3-ethernet "Wired connection 1".
I added a dmesg
4 years 11 months ago #226324 by roland206
Had problems with attachments
4 years 11 months ago - 4 years 11 months ago #226333 by tommylight
Assuming using the official 2.8, so Debian Buster with the built in WiCD network widget, so that will not work for using ethernet and wifi at the same time, it will disconnect etherenet as soon as you try to connect to wireless.
Also, you will have to set a static IP for the wired connection and connect the PC directly to the Mesa board.
help.ubuntu.com/community/WICD
see
Reverting to NetworkManager
Last edit: 4 years 11 months ago by tommylight. Reason: more info
4 years 11 months ago #226359 by roland206
Thanks for the reply.
However, as mentioned I have the same problem on another PC w/o WiFi.
Find attached the "ip a; uname -a" from the other PC with the same problem.
On the second PC it hapens less often (about every 3 minutes).
Anyhow, thx for helping
Roland
Time to create page: 0.057 seconds
