Mesa 7i76e connection lost
4 years 11 months ago #226378 by tommylight
In booth cases the same issue, there is no network setup for use with Mesa board, PC must have a static IP address to communicate with Mesa, the manual refers to setting the board IP to default 192.168.1.121 or to set it to 10.10.10.10. Depending on the above, the PC network should be set to 192.168.1.100 OR 10.10.10.11.
Never used WiCD so no idea how to set it to manual, but a quick search should return plenty of results, search for Linux WiCD, not LinuxCNC WiCD.
4 years 11 months ago #226419 by rodw
Replied by rodw on topic Mesa 7i76e connection lost
The docs outline how to make connections manually
linuxcnc.org/docs/2.8/html/man/man9/hm2_eth.9.html
If you are loosing wifi, try 2.4gHz as it has better range. I solved my problems doing that.
4 years 11 months ago #226437 by roland206
Thanks a lot. Problem solved.
I should have read the official doccumentation instead of following a youtube video promoting WiCD.
4 years 11 months ago #226460 by tommylight
My search-fu is failing, last night i spent 10 minutes searching for that and i failed!
Time to create page: 0.285 seconds
