Re-powering a Hardinge HC
- Tkaeding
13 Nov 2021 16:16 #226327
by Tkaeding
Re-powering a Hardinge HC was created by Tkaeding
Good morning everyone,
I bought a Hardinge HC chucker lathe with a bad motor and speed controller. I removed the motor, the spindle drive pulley and multi speed controller and all related pulleys and shives I want to replace with a VFD and 5 hp motor but I am someone confused as to pulley ratios. Any and all input would be greatly appreciated. My goal is to convert the cross slide to CNC, but now I am taking it step-by-step to be able to use as a manual wait until I’m ready to do the retrofit.
Thank you
Tom
Thank you
Tom
- BigJohnT
- Thank you received: 994
13 Nov 2021 23:48 - 13 Nov 2021 23:49 #226391
by BigJohnT
Replied by BigJohnT on topic Re-powering a Hardinge HC
I have a Hardinge CHNC I and if I'm not mistaken the HC is the same basic lathe? Do you have a photo of the machine? My CHNC does 6000 RPM so depending on the motor and VFD you select and the RPM you want that would dictate the ratio needed. For example if you need 6000 RPM and you have a motor that can take 120 freq and go say double the rated speed of 1800 that would give you 3600 RPM so almost 2 to 1 ratio to get 6000 but that just depends on your needs.
A 5 HP motor would require 3 phase power either from the grid or from a rotary phase converter which is easy to make but VFD's don't like getting power from a RPC IIRC.
JT
JT
Last edit: 13 Nov 2021 23:49 by BigJohnT.
- Thank you received: 4652
21 Nov 2021 23:08 #227245
Replied by andypugh on topic Re-powering a Hardinge HC
I would suggest that 6000 rpm is so rarely useful on a lathe that you might want to gear for slower to get a larger cut on larger work.
My lathe is rated for 3000 rpm but the macros that I generally run top out at 2500 (inherited from a previous lathe) and this bothers me so little that I have not changed it.
If you make a _lot_ of tiny parts then perhaps it makes sense to gear for 6000, but even with carbide tooling 6000rpm is only needed on parts smaller than 4mm diameter (in steel)
- OT-CNC
- Thank you received: 75
21 Nov 2021 23:52 #227252
by OT-CNC
Replied by OT-CNC on topic Re-powering a Hardinge HC
What chucker do you have? Pics?
I have done a 1:1 drive with a long herringbone belt on my converted AHC. 5hp on 3ph and vector drive with encoder card. Plenty of power for rigid tapping although I have not tested it's limits.
I keep mine below 4k rpm as the long belt introduces some vibes at higher numbers.
Here is a link to a thread with more info (similar setup but not mine) :
forum.linuxcnc.org/show-your-stuff/34456...sion?start=20#199041
Time to create page: 0.137 seconds
