G-code decoding problem?
  • chen1234
  • chen1234's Avatar Topic Author
  • Senior Member
  • Senior Member
15 Nov 2021 03:16 #226532 by chen1234
G-code decoding problem? was created by chen1234
Hi everyone, I ran into a problem while trying to make a custom M code.
I need to implement a "decoding pause" function.
Its function on an NC device is probably: when G code is decoded, the "macro variable assignment" thread and the "G code running" thread can be paused synchronously.
When a custom M code (such as M100) is encountered, the "decoding pause" function will be realized, the PLC will execute the operation and feedback the completion status, and then click "start" or "next" to continue decoding.
Does linuxcnc have this function? Or is there any way to achieve this function?
Thank you all in advance, my use of Google Translate may be inaccurate.
15 Nov 2021 04:20 #226537 by Henk
Replied by Henk on topic G-code decoding problem?
Custom Modes execute typical Hal commands using a bash script. Not sure if it will execute a g code sub. I think to do that you are better off remapping the m code.
​code. Search for linuxcnc remap
you can use a simple subroutine call o<prog_name> call to call a g code subroutine. In this sub, m66 can be used to wait on input from the PLC. After that M0 will pause the program until you press resume or step.
Henk
The following user(s) said Thank You: chen1234
  • chen1234
  • Senior Member
  • Senior Member
15 Nov 2021 07:26 #226548 by chen1234
Replied by chen1234 on topic G-code decoding problem?
Thank you for your answer,
I will try to remap the code and use M66/M0.
I asked my colleague again, and he said: The function of "Decoding Pause" is: the decoding system will pause decoding after it reaches M100.
After the NC finishes executing M100, it informs the decoding system to start to continue decoding.
The M code will be sent to the PLC, and some auxiliary operations will be completed through the PLC.
So what is the way linuxcnc parses G code?
Will there be a thread for "macro variable assignment" to execute?
If not, how to realize the function of decoding pause?
Or is this feature necessary for Linuxcnc?
Hope someone can give me some pointers,
thank you.
15 Nov 2021 15:39 #226584 by Henk
I'm the remap python files there is a way to make the interpreter to wait until your code has completed. I don't know the detail, but it should be in the docs.
​​​​​​I Don't know the bash script that well, but I'm sure you will be able to do what you want using that method. It pauses the g code until your bash script exits. It may be a simpler sollution.
  • chen1234
  • Senior Member
  • Senior Member
16 Nov 2021 01:14 #226617 by chen1234
Thanks Henk,
I used this method in the remapping code, it can wait for my code to complete before continuing to the next G code.
def g021(self, **words):
    yield INTERP_EXECUTE_FINISH
    if self.task:
        list = []
        for key in words:
        MESSAGE("word '%s' = %f" % (key, words[key]))
        list.append(words[key])
        res = str(list[0])+' '+str(list[1])+' '+str(list[2])
        main = "/home/.../linuxcnc/...../BBB"  #Executable path
        out = os.system(main +' '+ res)
I still have a question, (maybe I can't express it clearly when I use translation software).
How does LInuxcnc decode the G code file, which can be seen in that file?
Time to create page: 0.096 seconds
