I received my vfd and spindle
  • PhilipME
  • PhilipME's Avatar Topic Author
  • Elite Member
  • Elite Member
16 Nov 2021 13:47 #226651 by PhilipME
I received my vfd and spindle was created by PhilipME
Good day
I ordered the kit( vfd+spindle ) from G-Penny. In the picture they show huanyang vfd. But when I received the kit, it turned out that the vfd is changzhou. I should have specified the vfd before the order. It is my fault.
I spent a week studying the huanyang vfd ( No body should laugh). If I get a huanyang vfd now, I can serial connect it to linuxcnc.
there are 2 useful videos in youtube about setting the changzhou vfd, but nothing about serial communication.
Not sure if this changzhou vfd similar to yalang or to huanyang or its own vfd. or if linuxcnc has a driver for it.
I still can run it manualy, or via 0-10 volt signal, but it will be cool if I can read the rpm.
Best regards
18 Nov 2021 18:40 #226906 by andypugh
Replied by andypugh on topic I received my vfd and spindle
If the picture isn’t what they sent then I would attempt to get them to swap it.
  • PhilipME
  • Elite Member
  • Elite Member
19 Nov 2021 09:47 - 19 Nov 2021 10:47 #226962 by PhilipME
Replied by PhilipME on topic I received my vfd and spindle
Thanks Andy
It will take very long time for sending back and re-delevering assuming they will agree to replace the vfd.
I already started the motor from linuxcnc machine via analog 0-10 volt, and working on the calibration. It does not run at the speed I input to linuxcnc machine. Not sure where to look for calibration/scale but I will find it. ( when I adjust the values in the stepconf in the spindle page, the behavior is not linear)
So I will work with this vfd using analog communication, and I will study the vfd generic driver for linuxcnc when I am out of the building phase and can spare more time.
Best regards
Philip
Last edit: 19 Nov 2021 10:47 by PhilipME.
19 Nov 2021 11:56 #226970 by andypugh
Analog control is more realtime anyway, I sometimes wish that I had chosen that for my lathe as sometimes you can hear the steps in speed control on facing cuts.
The following user(s) said Thank You: PhilipME
Time to create page: 0.098 seconds
