LinuxCnc M3 S0
16 Nov 2021 19:36 #226674 by Kost
LinuxCnc M3 S0 was created by Kost
Hello!
I'm using linuxcnc 2.7.14, and get some troubles with spindle control. I want to start spindle with M3 S0, and later set S to some number. But it doesn't spin after S0. In active g-codes i have M3 and desired S, button "run" in axis is pressed, but net spindle-on is always false and spindle-speed-cmd is 0. If i start the spindle with M3 S100, stop it with S0 and start again with S100 spindle doesn't run with symptoms above.
Manual says that using  M3 S0 is ok, nothing wrong with it. I know that i can use M5 and other commands, remap something and more... But why it doesn't work in that simple case? Maybe this is known problem?
16 Nov 2021 22:41 #226684 by Clive S
Replied by Clive S on topic LinuxCnc M3 S0
Hello!
Have you tried M3 S1000 ? I am not sure without test but M3 S0 you are asking it to give a speed of zero
17 Nov 2021 01:20 #226691 by cmorley
Replied by cmorley on topic LinuxCnc M3 S0
This is known. Changed in master branch.
The following user(s) said Thank You: Kost
18 Nov 2021 17:42 #226895 by Kost
Replied by Kost on topic LinuxCnc M3 S0
I found a poor man's workaround for this bug, signal spindle-brake works with m3 s0 and m5. Take this to inverter, remap S to m68, and my problem solved. Spindle-brake has adequate reacton for estop and program stop.
Time to create page: 0.159 seconds
