Why my break out board making this noise when I click spindle on?
  • PhilipME
  • PhilipME's Avatar Topic Author
  • Elite Member
  • Elite Member
17 Nov 2021 16:13 - 18 Nov 2021 04:43 #226758 by PhilipME
Setting up ny vfd and spindle? was created by PhilipME
Good day
I am trying to set up my vfd and eventyaly connect it to linuxcnc
Also I do not hear the onboard relay clicks
Philip
Last edit: 18 Nov 2021 04:43 by PhilipME.
17 Nov 2021 16:36 #226763 by itsme
I would say wrong cabling...
It seems the Relais is switching it's power off itself.
The following user(s) said Thank You: PhilipME
  • PhilipME
  • Elite Member
  • Elite Member
17 Nov 2021 17:31 - 18 Nov 2021 04:44 #226767 by PhilipME
I think you are right, I am using the wrong pins for my type of bob. I randomly assigned the spindle, and pwm pins while, the should be bob specific.
but I can not get my voltmeter to read a value in the 0-10 vdc output pins from the bob.
I want to feed that signal to the spindle.
Philip
Last edit: 18 Nov 2021 04:44 by PhilipME.
  • PhilipME
  • Elite Member
  • Elite Member
17 Nov 2021 18:23 - 18 Nov 2021 04:41 #226769 by PhilipME
Now I am able to get voltage out of the 0-10vdc pins (pwm signal must outputs to pin p01 in my bob, because internaly pin 01 is connected to the 0-10 through whatever circut that generates the 0-10 volts and linuxcnc stepconf wizard defaults pin01 for estop-out. I fixed that)
I will be looking now for calibration, I mean the place where I set my 100%(10 volts) because now it tops at 2000 rpm
Edit : I already set the min, and max speed to the min and max voltage. Every thing working fine.
Now it is time to wire the vfd to the bob. I will wire the M03, and 0-10 volt, and the ground. nothing else. No need for M04 at this time.
Philip
Last edit: 18 Nov 2021 04:41 by PhilipME.
Time to create page: 0.136 seconds
