Interpretation of G code?
- chen1234
21 Nov 2021 23:38 #227269
by chen1234
Interpretation of G code? was created by chen1234
I have an NC code, it may not be suitable for cnc code.
This code may be different from cnc when it is interpreted.
There will be two threads working at the same time during execution, the "parameter assignment thread" and the "G code execution thread".
This NC code contains an M code (M100), its function is to synchronize two threads, so that the G code is executed in line order.
For example, when it is executed (#963=0), it will execute the "parameter assignment thread".
Then execute the "G code execution thread" to run the G code, until the next occurrence (#963=1) will continue to execute the "parameter assignment thread".
I saw on the website that the cnc interpreter executes G code line by line. Does it need this feature (M100)?
Below is the code:
Below is the code:
;M100 Synchronous thread
N1
IF [#800==1]GOTO10 ;(The processing flow jumps to the processing program)
END_IF
IF[#801==1] ;(If not, the processing flow jumps to_ ERR1)
GOTO2000
END_IF
G4X0.5
GOTO1
;*******************Machining code*********************
N10 M100
;#963 ;Floor alarm flag setting
#733=-550;Z-axis safety coordinate
#950=8 ;(DEP)
#970=#750+#752
#971=#750+#752+#754
#972=#750+#752+#754+#756
#973=#750+#752+#754+#756+#758
#740=#750*#751+#752*#753+#754*#755+#756*#757+#758*#759
;******************Machining master program*******************
@9999=5503 ;("End of processing flow!")
@9998=0
IF [#702>#733]GOTO1010 ;(Z axis is greater than safety coordinate, jump to_ ERR2)
END_IF
G53 G90 G01 Z#733 F3000 ;Z axis reaches safety coordinate
N300 ;(_ALM:)
IF[#740<#950] GOTO310 ;(STA)
ELSE
GOTO1020 ;Machining depth exceeds
END_IF
N310 M143 ;(STA)
M100
#749=1(The layer counter is set to 1)
#963=0 ;The number of floors alarm flag is set to 0
G90 G01 Z=#733 F3000
IF [#820==1] ;Determine whether it is a galvanometer light path
GOTO 400
END_IF
IF[#822==0] ;If the machining head is in internal mode, skip to_ NBMS
GOTO 600
END_IF
GOTO330
;********Machining head internal mode part*******
N600 ;NBM
WAIT PX15.07 V1
G90 G01X#700 Y#701 F3000; M140 M100
G90 G01 A#703 B#704 C#705 F3000
G90 G01 Z#702 F3000
M135
M120 ;(STARTBLOW)
M141 ;(opening the light)
M125 ;(M60 Turn on the wear detection function)
G4X0.5
WAIT PX13.07 V0 ;Wait for the hole making status to be set to 0
M145 ;Turn off hole making signal
GOTO640
N635 M100
#963=1 ;The number of floors alarm flag is set to 1
N640 M100 ;Wait for the allowable feed signal M88
#749=1 ;(R69=1
M126
M142
M121 ;(M11)
IF [#963==0]
GOTO700
ELSE
@9999=5501 ;("Note: when the number of layers to be processed ends, press cycle start to continue")
@9998=1 ;(PLS INPUT ROW QTY)
;M0
#963=0
END_IF
N700 M100
M132 ;(M82Current process completion signal)
;@9999=5502 ;("Current hole machining completed")
;@9998=1 ;(PLS INPUT ROW QTY)
;M0
G4X1
;WAIT PX0.03 V1
IF [#815==1]
WAIT PX0.03 V1
GOTO310 ;Process end signal
ELSE
GOTO1710
;N735 M0()
;@9998=0 ;(PLS INPUT ROW QTY)
END_IF
N1010 ;_ERR2:
@9999=2203 ;("#2 Z_SafePos The variable setting is too small !")
GOTO1750
N1020
@9999=2201 ("If the machining depth exceeds, please check the parameter setting")
GOTO300 ;
N1710 ;END2
GOTO1750
N1750 ;END
M100
M143
M144
;G90G01Z#733F3000
;MSG("")
;M99
M30 Please Log in or Create an account to join the conversation.
- Thank you received: 4658
22 Nov 2021 17:35 #227338
Replied by andypugh on topic Interpretation of G code?
I am not clear what you are trying to do, but G-code is basically a poor fit for multi-threading.
You might be able to do what you want by running a G-code loop and also a Python userspace function or HAL realtime thread in parallel.
(LinuxCNC already does this, for example halui runs in parallel to the motion control in userspace, as do the GUIs.)
The following user(s) said Thank You: chen1234
Time to create page: 0.138 seconds
