Encoder cable length?
- Catch22
- Thank you received: 17
22 Nov 2021 14:23 #227297
by Catch22
Encoder cable length? was created by Catch22
I just installed a new spindle encoder on my cnc lathe and the cable that came with it is about 2 meters long rolled up, I just wired it up like that and it works, should I shorten the cable it only needs to be about 8 inches long or will it be fine as it is. just not sure if it throws anything off when its that long.
Thanks Mike
Thanks Mike
- Thank you received: 7468
22 Nov 2021 14:44 #227298
Replied by tommylight on topic Encoder cable length?
Better leave it as is.
The following user(s) said Thank You: Catch22
- Catch22
22 Nov 2021 15:01 #227300
by Catch22
Replied by Catch22 on topic Encoder cable length?
Ok will do, thanks.
Time to create page: 0.244 seconds
