HOME_Index_only
26 Nov 2021 06:29 #227620 by wang
HOME_Index_only was created by wang
Hello everyone
I have never understood the role of Index in the HOME movement, because I am not sure who produced this Index.
Can anyone help me explain the flow of HOME movement when Index_only?
26 Nov 2021 10:53 - 26 Nov 2021 10:55 #227636 by d2inventory
Replied by d2inventory on topic HOME_Index_only
The index signal comes from your encoder. Your glass scale has an index mark every 50mm f.e, now you can run the machine to the mechanical switch or hall sensor and then from there you can use the glass scale to find the accurate home position using those 50mm index marks.
So basically the index is just the high accuracy home "switch".
I reckon index only is used for rotary encoders where you only get one index position so you don't need a switch to pre-locate a rough home position.
Last edit: 26 Nov 2021 10:55 by d2inventory.
