Mesa 7i97 ethernet problem
- mosoeng
26 Nov 2021 13:47 #227647
by mosoeng
Mesa 7i97 ethernet problem was created by mosoeng
Very new to this, just installed LinuxCNC 2.8
Debian 10
and hooked up the Mesa 7i97 to computer with ethernet cable.
I can ping card on 192.168.1.121 and 10.10.10.11 but when I run mesaflash --device 7i97 --addr 192.168.1.121 --readhmid
I get mesa 7i97 not found error, ols help asap.
Mike
Mike
- Thank you received: 7468
26 Nov 2021 13:54 #227649
Replied by tommylight on topic Mesa 7i97 ethernet problem
In a terminal
ip a
what does it say ?
ip a
what does it say ?
- mosoeng
26 Nov 2021 14:01 #227650
by mosoeng
Replied by mosoeng on topic Mesa 7i97 ethernet problem
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 50:af:73:29:ad:9e brd ff:ff:ff:ff:ff:ff
3: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 50:af:73:29:ad:9f brd ff:ff:ff:ff:ff:ff
inet 192.168.1.121/8 brd 192.255.255.255 scope global enp3s0
inet6 fe80::52af:73ff:fe29:ad9f/64 scope link
4: wlp1s0b1: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:8e:f2:6f:0d:14 brd ff:ff:ff:ff:ff:ff
26 Nov 2021 16:31 #227661
The PC's IP address is wrong, it should be anything but 121 at the end.
121 is Mesa boards address.
Where did you find the info about setting it to 121?
We have to remove that info as it is wrong and causing confusion.
- mosoeng
26 Nov 2021 18:04 #227667
by mosoeng
Ok thnx, its sorted with above advise.
Time to create page: 0.339 seconds
