Feedback loop following error
- bobi4ko23
03 Dec 2021 15:55 #228298
by bobi4ko23
Replied by bobi4ko23 on topic Feedback loop following error
What if i just comment them? Would that work as well? I did that I now realised I uploaded an old version.
- bobi4ko23
03 Dec 2021 19:39 #228308
by bobi4ko23
Okay, so after some work on the machine turns out that I have a following error because the encoder doesn't tell the machine to stop. The stepgen position is relatively okay (+/- 0.2 mm) (so the stepscale is fine), and the encoder count position is also okay +/- 1 count (0.005 mm). So why doesn't the encoder tell the axis to stop? I set following error 25 mm and if i move it 1mm it stops on 24mm (following error). What parameters do i check to see if the motor is taking commands from the encoder feedback? I didn't provide a f-error halscope because i see no point in that at the moment because the PID parameters have 0 effect on the movement (i tried to mess with them a little but to no effect). Please help!
- Thank you received: 5308
03 Dec 2021 20:30 - 03 Dec 2021 20:31 #228311
Replied by PCW on topic Feedback loop following error
Not sure what you are saying. If you set both following errors to 25 mm you need to be 25 mm out of position before a following error is generated. Even if P is 0 (no feedback at all) you should be closer than this for al least a few moves because the velocity command stream should be very close to right.
The reason for a plot is so others can see what's happening and possibly diagnose
the problem. A plot of velocity and following error would help a lot.
Last edit: 03 Dec 2021 20:31 by PCW.
- chris@cnc
- Thank you received: 140
03 Dec 2021 20:58 #228313
by chris@cnc
Replied by chris@cnc on topic Feedback loop following error
Yes, plot of data would be helpful.
Not sure if i understood right. The situation is: You move axis 1mm and encoder / Gui data run ahead and stop on max error. If so i guess wiring issue on encoder.
Your command position data X-axis goes this way.
x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
check this data in halshow. first must stop after 1mm second zero after 1mm
feedback from encoder
net x-pos-fb <= hm2_7i96.0.encoder.00.position
net x-vel-fb <= hm2_7i96.0.encoder.00.velocity
usually same as command data
If not, your encoder is wrong wired. Maybe TTL or RS422 mixed or what kind is used.
And in your hal are this lines in all axis double.
net x-pos-fb => joint.0.motor-pos-fb
One in
# ---closedloop stepper signals---
and
One in
and
- bobi4ko23
03 Dec 2021 21:48 - 03 Dec 2021 21:53 #228314
by bobi4ko23
I tell it to go for 1mm and it doesnt stop to move until the following error is reached. What should I change in the hal files other than delete the duplicate lines?
In encoder count the encoder works fine and the stepgen also showes close to the right value when following error is reached. So I dont think the encoder is wired wrong.
Also the encoder is TTL and the jumper is in the right position.
Last edit: 03 Dec 2021 21:53 by bobi4ko23. Reason: Extra info
- chris@cnc
03 Dec 2021 22:17 - 03 Dec 2021 22:18 #228317
by chris@cnc
first command position second command speed. What Show this after command 1mm step?
Last edit: 03 Dec 2021 22:18 by chris@cnc.
- bobi4ko23
03 Dec 2021 22:21 #228318
by bobi4ko23
I will change it and inform you tomorrow. Thank you very much.
- bobi4ko23
03 Dec 2021 22:28 #228319
by bobi4ko23
These parameters are like this in my hal file? What do i change to?
net x-pos-cmd <= joint.0.motor-pos-cmd
- chris@cnc
03 Dec 2021 22:43 #228322
by chris@cnc
This line not change. This your command Position data. Check this data in halshow. You must search why your velocity data or command data not stop. I can not See what is wrong,
- bobi4ko23
03 Dec 2021 22:48 #228323
by bobi4ko23
Okay after i see the results i will send you tomorrow. Thank you very much for your help.
Time to create page: 0.827 seconds
