Shift Register Port Expander, lsrio16 comp
- DoWerna
- Thank you received: 57
29 Nov 2021 20:17 #227942
by DoWerna
Replied by DoWerna on topic Shift Register Port Expander, lsrio16 comp
yes I have to build something like that
- Muncie
- Visitor
01 Dec 2021 09:39 #228102
by Muncie
Replied by Muncie on topic Shift Register Port Expander, lsrio16 comp
Nice
- DoWerna
02 Dec 2021 11:47 #228181
by DoWerna
After I had everything there, I equipped a new board.
A first test with wire bridges at the inputs worked.
Let's see if it also works in the panel
- DoWerna
04 Dec 2021 16:34 #228348
by DoWerna
the new board sits in the panel, but strangely still have the same error pattern
so some buttons always work, some don't.
The faulty inputs are exactly the same with the new board as with the first board.
do not think that the error is in the hardware.
I tried to understand the logic of the shifter with the HalScope, but did not understand anything.
Now I tried to change the shift period and update time in the component (wiki.linuxcnc.org/uploads/lsrio16.comp).
I always recompiled it.
also without success.
Translated with www.DeepL.com/Translator (free version)
- Thank you received: 5321
04 Dec 2021 17:57 - 05 Dec 2021 15:13 #228355
Replied by PCW on topic Shift Register Port Expander, lsrio16 comp
I would try adding a series resistor (say 1K) and a small capacitor (say 1000 pF) to ground
on the shift clock line at the input to the Schmitt trigger. The input shift register parts are very fast
(typically 96 MHz shift clock @ 5V) and any ringing/undershoot on the shift clock line is liable to
double clock the register. A RC filter(the 1K R and 1000 pF C) followed by the Schmitt trigger will clean
up any ringing/crosstalk SI issues with the parallel port signals.
Last edit: 05 Dec 2021 15:13 by PCW.
The following user(s) said Thank You: tommylight, DoWerna
- DoWerna
04 Dec 2021 21:01 #228363
by DoWerna
YEAH
I had only 220pf there, so I made 2 RC filters with 2x220pF parallel and 1K resistor at SCK and RCK.
Now runs perfectly
Thank you very much,
Werner
Now runs perfectly
Werner
Time to create page: 0.117 seconds
