"first version tried even if "
30 Nov 2021 17:55 #228049 by jtrantow
"first version tried even if " was created by jtrantow
I'm configuring a few new boxes (with an older usb boot drive) and ran into a few install problems. (finding repositories, etc.)
I went to the linuxcnc.org/downloads/ to grab a new iso starting point and the docs there indicate both "It should probably be the first version tried even if using a parallel port."
The "LinuxCNC 2.8 Downloads" section uses a link/description vs the "LinuxCNC 2.7 Downloads" section using a description/link order.
If you can confirm that 2.8.2 Debian 10 Buster PREEMPT-RT-ISO is now the preferred starting point, I could update this page to clarify downloads.
  • Moderator
  • Moderator
06 Dec 2021 23:12 #228480 by tommylight
Replied by tommylight on topic "first version tried even if "
Sorry for the late reply,
Yes 2.8.2 is the latest official release, others are EOL so not supported anymore.
Time to create page: 0.075 seconds
