Wiring VFD to Mesa 7i76E
- ryanmontrose
03 Dec 2021 05:43 #228258
by ryanmontrose
Wiring VFD to Mesa 7i76E was created by ryanmontrose
Hello all,
I am having difficulties setting up my H100-1.5C2-1B VFD to my Mesa 7i76E.
Background:
The Ethernet connection between the 7i76E & computer is working, I'm able to ping the board, and the board is recognized within Pncconf wizard.
While in manual mode (i.e. F001=0: keyboard, F002=3: potentiometer of keyboard) I'm able to control the frequency via potentiometer located on the face of the VFD. However, I would like to control the frequency/spindle speed using my Mesa card. (Not sure if reverse direction is needed but wouldn't hurt to have)
I have largely based my connection attempts using the diagram presented in here .
A pinout of the VFD is viewable here .
I've taken the liberty to attach photos of the VFD manual here . (Haven't been able to find an online copy)
If someone could help me make the proper wiring connections and Pncconf spindle settings, I would be greatly appreciative!
Best regards,
Ryan
Background:
Best regards,
Ryan
- d2inventory
- Thank you received: 10
03 Dec 2021 11:09 - 03 Dec 2021 11:11 #228274
by d2inventory
Replied by d2inventory on topic Wiring VFD to Mesa 7i76E
Is J3 set to V?
Have you tried with a manual poti?
Last edit: 03 Dec 2021 11:11 by d2inventory.
- ryanmontrose
04 Dec 2021 17:55 #228354
by ryanmontrose
Replied by ryanmontrose on topic Wiring VFD to Mesa 7i76E
Yes, J3 is set to V.
I was able to get it working with the potentiometer on the face of the VFD if thats what you are asking.
- 0x2102
- Thank you received: 88
04 Dec 2021 18:47 #228359
by 0x2102
Replied by 0x2102 on topic Wiring VFD to Mesa 7i76E
Did you set all motor related parameters or were those pre-configured?
Like rated power, rated voltage, rated current, rated Hz, max Hz etc... or do you need help as well?
- d2inventory
07 Dec 2021 22:59 #228577
by d2inventory
No I meant an external one, or just use 2 resistors to see if any external input works.
- gitin
- Thank you received: 9
08 Dec 2021 16:19 - 08 Dec 2021 16:21 #228633
by gitin
Replied by gitin on topic Wiring VFD to Mesa 7i76E
I don't have a 7I76E, this setup works on another board.
F001 =1
F002=1
F044=1
F045=5
Spindle Enable + X1
Spindle Enable - GND
Spindle DIR + X2
Spindle DIR - GND
Spindle + P12
Spindle OUT AI1
Spindle - GND
F001 =1
F002=1
F044=1
F045=5
Spindle Enable + X1
Spindle DIR + X2
Spindle DIR - GND
Spindle + P12
Spindle OUT AI1
Spindle - GND
Last edit: 08 Dec 2021 16:21 by gitin.
Time to create page: 0.116 seconds
