7i76e expansion ports don't work properly
08 Dec 2021 17:20 #228640 by raychar
I set some gpio pins as inputs and outputs, the inputs work but not for outputs. Firstly, I wrote down the respectively statements in the custom hal file. A momentary switch is connected to the input, but the voltage measured on the output is always at high level (i.e is always at 5v or always at 2.7V when having resistor loaded to it). However, In the hal meter observations, they both show true and false changing words when the switch is pressed.
Thanks,
08 Dec 2021 18:32 #228642 by PCW
Did you set the "is_output" attribute for the GPIO pins used as outputs?
09 Dec 2021 12:54 #228698 by raychar
Replied by raychar on topic 7i76e expansion ports don't work properly
Properly no, so where and how to set it?
  • Moderator
  • Moderator
09 Dec 2021 16:08 #228708 by tommylight
Replied by tommylight on topic 7i76e expansion ports don't work properly
Example:
setp hm2_5i25.0.gpio.000.is_output true
09 Dec 2021 17:09 #228718 by raychar
> it works now, thanks,
1) is it the same effect by configure the pncconf by clicking the corresponding IO checkbox to output instead of the default input?
2) I did above 2) before, but I think I mess them up without using the new generated[machine_name].hal, file as I kept on using the old one to replace new one, it is because the new one failed to start up. For the old one, I manually wrote something there so it is ok in starting up....somehow..so long time...that I forgot what stuffs i wrote there ...added axis...screen..
anyway, thanks,
