external jog-speed select button not working after homing
- oeleboele
14 Dec 2021 14:13 #229058
by oeleboele
external jog-speed select button not working after homing was created by oeleboele
I've a external jog-speed selector switch connected and two switches for +/- jogging x and y axis.
Everything is working except that after homing the jog speed selection does nothing.
I connected the halui.axis.jog-speed and halui.joint.jog-speed to the switch so I don't know what I'm doing wrong. Before homing the speed selection does work.
Does anybody know what I'm missing here?
This is how I connected it in hal:
loadrt mux2 count=1
addf mux2.0 servo-thread
setp mux2.0.in1 3000
setp mux2.0.in0 1500
net jog-spd-sel-ext-fast mux2.0.sel <= hm2_7i76e.0.7i77.0.2.input-06
net jog-speed <= mux2.0.out => halui.axis.jog-speed halui.joint.jog-speed
net jog-x-neg halui.joint.0.minus halui.axis.x.minus <= hm2_7i76e.0.7i77.0.2.input-08
net jog-x-pos halui.joint.0.plus halui.axis.x.plus <= hm2_7i76e.0.7i77.0.2.input-09
net jog-y-neg halui.joint.1.minus halui.axis.y.minus <= hm2_7i76e.0.7i77.0.2.input-10
net jog-y-pos halui.joint.1.plus halui.axis.y.plus <= hm2_7i76e.0.7i77.0.2.input-11
loadrt mux2 count=1
- Michael
- Thank you received: 59
15 Dec 2021 06:22 #229099
by Michael
Replied by Michael on topic external jog-speed select button not working after homing
Is this a new setup or adding on to an existing config?
Are you stuck on a shared limit switch after homing?
Also you shouldn't need to have jogs for joint and axis connected. An axis jog command will move all joints associated with that axis. Try removing the joint pins.
- Thank you received: 2175
15 Dec 2021 12:48 #229122
Replied by cmorley on topic external jog-speed select button not working after homing
please post your config files.
Time to create page: 0.083 seconds
