Missing halui pins
- garthnoakes
- Thank you received: 9
15 Dec 2021 03:24 #229092
by garthnoakes
Missing halui pins was created by garthnoakes
Where is halui.joint.N.analog in 2.7?
I am trying to get the simple remote pendant example working, not having much success
net jog-x-analog <= mux2_x.out => mux2_x.in0 halui.joint.0.analog halui.axis.x.analog
net jog-y-analog <= mux2_y.out => mux2_y.in0 halui.joint.1.analog halui.axis.y.analog
net jog-z-analog <= mux2_z.out => mux2_z.in0 halui.joint.2.analog halui.axis.z.analog
- Michael
- Thank you received: 59
15 Dec 2021 05:37 #229095
by Michael
Replied by Michael on topic Missing halui pins
Can you describe where you are looking for it? Some of the halui pins don't show up until after the gui is turned on I believe.
Can you find the pin in halmeter or halshow? What's your ini and Hal file like
- ALittleOffTheRails
- Visitor
15 Dec 2021 07:51 - 15 Dec 2021 07:53 #229101
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Missing halui pins
2.7 has these 2 pins linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
halui.jog.N.analog
halui.jog.deadband
2.8 has these 4 pins linuxcnc.org/docs/2.8/html/man/man1/halui.1.html
halui.joint.jog-deadband
halui.jog.N.analog
halui.jog.deadband
Jogging using joints was introduced to v2.8
halui.jog.N.analog
halui.jog.deadband
halui.jog.N.analog
halui.jog.deadband
Last edit: 15 Dec 2021 07:53 by ALittleOffTheRails. Reason: add ref tp docs
- garthnoakes
15 Dec 2021 15:10 #229134
by garthnoakes
Replied by garthnoakes on topic Missing halui pins
Excellent! my joypad is now working, still needs some adjustments but I can at least control x, y and z from it or the keyboard.
Thanks a stack
Thanks a stack
- garthnoakes
15 Dec 2021 15:12 #229135
by garthnoakes
I was looking in the GUI under Machine/halui. But the reply below has sorted out the problem - and I can see the pins mentioned.
- seuchato
- Thank you received: 126
03 Nov 2022 14:23 #255845
by seuchato
Replied by seuchato on topic Missing halui pins
Hi could you kindly post what and how you actually changed?
I got the same/similar problem, but can't figure it out
greez
chris
greez
chris
Time to create page: 0.215 seconds
