Motors Powered but no Movement
19 Dec 2021 02:19 #229464 by 42walrustitan
Motors Powered but no Movement was created by 42walrustitan
This is my first post so I dont know if I am in the right place.  Please bear with me.
Recently I got a surplus K2 CNC router and have been trying to get it running.  I know the servos are getting power and have goten the machine to move once.  However now it no longer moves but the E-Stop and home switches still work. I know the servos are still getting power but I cant get them to move. Any Ideas would be great.
  • Moderator
  • Moderator
19 Dec 2021 08:44 #229473 by tommylight
Replied by tommylight on topic Motors Powered but no Movement
Not much info to go on, so what comms? Parallel or Eth or analog?
Pictures and hal and ini files uploaded here would help.
19 Dec 2021 18:37 #229502 by 42walrustitan
Replied by 42walrustitan on topic Motors Powered but no Movement
I am using a parallel port and I have attached my hal and ini files.
File Name: my-mill-ini.txt
File Size:2 KB
File Name: my-mill-hal.txt
File Size:4 KB
  • Moderator
  • Moderator
19 Dec 2021 22:24 #229515 by tommylight
In the hal file:
loadrt hal_parport cfg="ec00 out"
setp parport.0.reset-time 3500
change to:
loadrt hal_parport cfg="0xec00 out"
setp parport.0.reset-time 5000
And we need something to confirm that the charge pump is actually required on pin 17, any PDF or picture of the board with written functions or...
23 Dec 2021 04:52 #229791 by 42walrustitan
I made the changes you said and I got the machine to move!!. However, after I closed the program when I opened it again I no longer get a response from the machine.
23 Dec 2021 07:01 #229796 by gitin
Replied by gitin on topic Motors Powered but no Movement
Sorry, I don't speak English well. It works like this for me.
loadrt stepgen step_type=0,0,0,0
loadrt charge_pump
#net estop-out charge-pump.enable iocontrol.0.user-enable-out
net motion-enabled charge-pump.enable motion.motion-enabled
net charge-pump <= charge-pump.out
loadrt pwmgen output_type=1
