The axis of rotation has no negative direction
- jess
22 Dec 2021 08:15 - 22 Dec 2021 08:17 #229705
by jess
The axis of rotation has no negative direction was created by jess
I am a novice and am configuring a 5-axis program on raspberry PI 4 using GPIO to output pulses.
But in the simulation, I found that my axis of rotation had no negative direction, so that it always rotated 360°.
For example, if axis A moves from 30° to 0°, axis A will rotate 330° instead of -30°
I hope to get your help and I will be grateful.
Last edit: 22 Dec 2021 08:17 by jess.
- Michael
- Thank you received: 59
22 Dec 2021 15:39 #229741
by Michael
Replied by Michael on topic The axis of rotation has no negative direction
Will need some config files to help sort it out. Hal and ini
- jess
23 Dec 2021 00:54 - 23 Dec 2021 00:55 #229783
by jess
Replied by jess on topic The axis of rotation has no negative direction
这是我的配置文件,我是通过Stepconf配置复制过来的,可能有点乱。
Last edit: 23 Dec 2021 00:55 by jess.
- Michael
23 Dec 2021 01:47 - 23 Dec 2021 01:50 #229785
by Michael
Just looked at this real quick. But how are you asking for it to go in a negative direction?
If your command is to move from A30 to A0 then it will move to that in a positive direction. It looks like if you were to ask for A-0 then it would go in the negative direction.
wiki.linuxcnc.org/cgi-bin/wiki.pl?WrappedRotaryAxes
www.forum.linuxcnc.org/49-basic-configur...-wrapped-rotary-axis
Also noticed you have in your INI "WRAPPED_ROTARY = 3" and was wondering what that means.
Last edit: 23 Dec 2021 01:50 by Michael.
- jess
23 Dec 2021 03:55 #229787
by jess
Thank you very much
The articles were very useful to me, and he solved my problem
"WRAPPED_ROTARY = 3" this should be wrong, I didn't notice
Thank you again for
Thank you again for
The following user(s) said Thank You: Michael
Time to create page: 0.083 seconds
