Question???? JUMPY AXIS
- ORidge
01 Jan 2022 21:16 #230485
by ORidge
Question???? JUMPY AXIS was created by ORidge
I have a Smithy 1240 Combined mill and right now the axis's are sporatically jerky on ALL 3 axis's and with every jump/jerk they lose a few thounsandths position, I am wondering what may be causing this and I have looked and cleaned every connection I could find to each motor and the board connections in the computer. It is funny that it is All 3 axis's though and seems to be the worst in one direction over the other.
Any thoughts on what this may be or are my drivers/computer burned out?
- Thank you received: 7468
01 Jan 2022 23:43 #230501
Replied by tommylight on topic Question???? JUMPY AXIS
Not much to go on there.
More info, pictures/video ?
- ORidge
02 Jan 2022 01:59 #230515
by ORidge
Replied by ORidge on topic Question???? JUMPY AXIS
If I am running a program, it will run just fine however all of a sudden you will hear a stutter within the stepper motor axis once in a while but if I run the jogs and feeds slower it does better. basically every stutter lets just say I will lose .005 on position on that axis. I can't Video it right now due to a broken z axis ball screw.This happens on all axis's though so it seems like it may be in the drivers. Is there something that drives ALL 3 drivers that may be going bad? It used to always run just fine for years and all of a sudden started doing this. ??????Lightening??? I don't know.
02 Jan 2022 02:07 #230518
And yes lightning can mess things badly, we have plenty of that here.
Still, if you do not provide us with more info, there is not much we can help with, we need all the info.
So far i know you have a malfunctioning machine named Smithy, that's it.
Yes, power supply, rectifiers, capacitors, controller, controller power supply, communication errors, etc etc....Is there something that drives ALL 3 drivers that may be going bad? It used to always run just fine for years and all of a sudden started doing this. ??????Lightening??? I don't know.
- robertspark
- Thank you received: 216
02 Jan 2022 09:30 #230534
by robertspark
Replied by robertspark on topic Question???? JUMPY AXIS
www.google.com/url?sa=t&source=web&rct=j...raln0Q0u3A5d6CvfC2SN
has it got the wrong lubricant on the slideways and ball screws.... how did you break a z axis ball screw?
worn out or broken?
worn out or broken?
- arvidb
- Thank you received: 158
02 Jan 2022 12:45 #230543
by arvidb
Replied by arvidb on topic Question???? JUMPY AXIS
More guesses: latency spikes and/or
marginal step times
Run latency-histogram with the correct base and servo period settings and post a screenshot.
- ORidge
02 Jan 2022 22:22 #230579
by ORidge
It is a smithy 1240 combined CNC and I am struggling to send Videos, I could e-mail them to you if it is acceptable just give me an address. I have been using Vactra 2 oil for years. The ball screw broke during homing the machine and you can move the head with extreme ease except when the motor jerks of course. Weird, I have been machining for 30 yrs and this has me ?? I believe it is something driving the stepper motors?? The spindle motor runs smooth as glass still and for the most part it is only 1 way on the axis motors.
- ORidge
09 Jan 2022 19:45 #231257
by ORidge
I did run the latency test these are the results. I ran it 3 times with similar results each time
Max Interval (ns). Max Jitter (ns). last interval (ns)
Servo thread (1.0ms) 1009663 20109 984976
Base thread (25.0us). 33233 12686 30183
Time to create page: 0.270 seconds
