When attempting to home my machine
- dpedreira
03 Jan 2022 00:21 #230598
by dpedreira
When attempting to home my machine was created by dpedreira
When attempting to home my Probotix machine with LinuxCNC I encounter two problems:
1- the spindle slowly descends towards the table and will not stop unless I hit emergency stop.
2- or it correctly Z's but then starts to travel to the far right as if X,Y homing was at the far right instead of the far Left. When it arrives at far right it starts banging against the side wall. I hit emergency stop and bring it back far left to the homing area.
Anyone experience this and have a remedy?
- Thank you received: 4145
03 Jan 2022 03:20 #230613
Replied by rodw on topic When attempting to home my machine
MOst likely running the wrong direction in homing setup or home switch connected to wrong axis
Or home switches are wrong state.
- RNJFAB
- Thank you received: 59
03 Jan 2022 09:50 #230638
by RNJFAB
Replied by RNJFAB on topic When attempting to home my machine
1 - check connections are to the correct motors. 1 at a time.
2- change direction of home in ini file by adding a " - " symbol to go the opposite way to find home.
Time to create page: 0.206 seconds
