home all
02 Oct 2010 08:51 #4487
by aike
Replied by aike on topic Re:home all
HOME_SEQUENCE has to be set for each axes.
For example:
[AXES_0]
HOME_SEQUENCE=1
[AXES_1]
HOME_SEQUENCE=2
[AXES_2]
HOME_SEQUENCE=3
And the button "Home all" appears.
For example:
[AXES_0]
HOME_SEQUENCE=1
[AXES_1]
HOME_SEQUENCE=2
[AXES_2]
HOME_SEQUENCE=3
02 Oct 2010 19:17 #4497
by occesar_0
Replied by occesar_0 on topic Re:home all
Thanks, actually after define that parameter in my .ini file, the buttom "home all" finally appears,but after pressed it nothing happens, what should I do in this case? I must define it in another file?
Thank you for you time
02 Oct 2010 22:36 #4499
by Rick G
Replied by Rick G on topic Re:home all
Hello,
You might want to look at 4.3.1 Homing section of the Integrator manual.
Rick G
Rick G
06 Oct 2010 16:08 #4535
by occesar_0
The problem was that I had begun to define from 1 and not from 0, thanks.
15 Feb 2011 18:43 #7224
by daino
Replied by daino on topic Re:home all
Hello .
I have the same problem,Can you please explain in details how you did .Thanks a lot .
16 Feb 2011 00:28 #7227
by occesar_0
Hello Daino:
You just have to write in your .ini file the home sequence that you want.
In the part where you define particular axis values, for example axis_0, there are several kinds of values
You just have to add
HOME_SEQUENCE
Then the number depends on what axis do you want to search home first, it could be
[AXIS_0]
HOME_SEQUENCE=0
[AXIS_1]
HOME_SEQUENCE=0
[AXIS_2]
HOME_SEQUENCE=0
Which means that all the axis go to home at the same time or if you use
[AXIS_0]
HOME_SEQUENCE=0
[AXIS_1]
HOME_SEQUENCE=1
[AXIS_2]
HOME_SEQUENCE=2
Axis 0 go to home and after find it, Axis 1 search home and so on...
Let me know if this is helpful for you, maybe I would set you an example with my .ini file. but till tomorrow.
César
HOME_SEQUENCE
[AXIS_0]
HOME_SEQUENCE=0
[AXIS_1]
HOME_SEQUENCE=0
[AXIS_2]
HOME_SEQUENCE=0
[AXIS_0]
HOME_SEQUENCE=0
[AXIS_1]
HOME_SEQUENCE=1
[AXIS_2]
HOME_SEQUENCE=2
César
Time to create page: 0.116 seconds
