5 axis - SRT switchable kinematics
- alj333
14 Jan 2022 02:12 #231724
by alj333
5 axis - SRT switchable kinematics was created by alj333
In the process of changing from Mach3 /4 to Linux cnc. Have 90% of linux cnc, mesa etc all ready to go
Now looking for the best starting point for 5 axis Kinematics,
Bridge style 5 axis machine, Y table, X, Z, C, A on the bridge,
C rotation about Z, +/- 360 degrees and A aixs - after the C axis, (can change to
tilt about the X axis +-120deg.
C axis to the spindle (in the Z axis center line) has a small offset of around 30mm.
I had been working through XYZBC-srt from Rudy du Preez's paper, and edited for our setup, but looking at the new Kinematics in 2.9, I think I have a bit more to learn for the updates. and on how to switch the TCP kinematics on and off as needed.
looking for a start point for a switchable system, able to use tool center point control?
The machine is currently running Mach3 and I have customized the PP in fusion to handle the 5 axis head offsets,
however doing the TCP conversion in the post process is not ideal, hence the move to LinucCNC.
- Thank you received: 7468
14 Jan 2022 03:50 #231725
Replied by tommylight on topic 5 axis - SRT switchable kinematics
There are several sim configs included with LinuxCNC that you can play with and edit.
You can test those even if you do not want to install LinuxCNC as they work when booted from USB in Live mode, it just can not save stuff while running from USB.
- Thank you received: 2164
14 Jan 2022 13:14 #231754
Replied by Aciera on topic 5 axis - SRT switchable kinematics
As suggested, have a look at sim/axis/vismach/5axis/spindle-rotary-tilting/xyzbc-srt in the current master branch. This simulation config comes with 5 axis kinematics and the switchable kinematics feature and should give you a good idea of how to get your machine setup. Just load it from the selection window and it will create the config folder containing the relevant files for you.
The following user(s) said Thank You: tommylight, jschulze
- alj333
15 Jan 2022 11:31 #231885
by alj333
Replied by alj333 on topic 5 axis - SRT switchable kinematics
Just got sim xyzac-trt running, looks perfect - just edit to SRT machine and add in the required offsets for the machine
- alj333
26 Jan 2022 09:27 - 26 Jan 2022 09:30 #233159
by alj333
I have almost everything working - one issue remaining when using the TCP kinematics with the GUI DRO's that i can not solve.
I have set up another 3 axis router with linuxcnc this week - the machine works well.
For the 5 axis - I have used 5axiskins.c from the bridgemill sim example and added code for the spindle offset. - Code below.
This works correctly in the vismach simulator. ( i had an issue after zeroing an axis with the DRO updates)
On the real machine config, the axis moves generated by the kinematics appear to be fighting the gui / control command position.
using trivkins the machine config works correctly - all dro data and motion are correct.
when I switch to 5axiskins.c ( bridge kinematics )
The first issue - the DRO does not update when the machine is doing the home reference. Servo's move - can see the feedback in HAL show on the Mesa card, x-pos-fb, y-pos-fb pins etc.
after completing the home reference - DRO works with normal MDI commands
second issue.
moving B and C axis under TCP kinematics:
The x,y,z servos move with the TCP kins correction data as expected. HAL data looks correct but the DRO does not update correctly.
the x-axis DRO moves while Y and Z do not.
X DRO then jumps back to the original position with axis.0 follow error.
for example, I move the B axis, X-axis adjusts for a while then jumps back to the original value - The servo does not follow the jump.
the Y and Z axis DRO flicker but keep the original value,
but the y axis and z axis servo are moving with the TCP correction
looking for any ideas for anything I might have missed in the configurations.
Config is mostly clean from pconf - edit for 5 axis machine and 7i95mesa
added pins for the x,y offsets in the updated kins code.
running Debian 11, linuxcnc master branch
Thanks again for help.
Andrew
Modified 5akiskins.c
* Description: 5axiskins.c
* kinematics for XYZBC 5 axis bridge mill
* Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2007 Chris Radek
* Notes:
* 1) pivot_length hal pin must agree with mechanical
* design (including vismach simulation) and augmented
* with current tool z offset
* (typ: mechanical_pivot_length + motion.tooloffset.z)
* 2) C axis: spherical coordinates aziumthal angle (t or theta)
* projection of radius to xy plane
* 3) B axis: spherical coordinates polar angle (p or phi)
* wrt z axis
* 4) W axis: tool motion. Negative values increase tool radial
* motion example: drilling into body at b,c angles
* 5) W axis motion is incorporated into the motion of the
* joints used for X,Y,Z positioning and no motor or
* hal pin connections are required for the joint specified
* as JW. However, a joint must be configured for W to
* support display of the W axis letter value for
* complicated reasons. (motion/control.c computes joint
* positions only for the number of configured kinematic
* joints (NO_OF_KINS_JOINTS) and the joint positions
* are needed to display axis letters via inverse
* kinematics.
* 6) If no coordinates module parameter is supplied, kins
* will use the required coordinates XYZBCW mapped
* to joints 0..5 in sequence.
* 7) Multiple joints may be assigned to an axis letter
* with the module coordinates parameter
* 8) If a coordinates module parameter is supplied,
* the kins will map coordinate letters in sequence
* to joint numbers beginning with joint 0.
* 9) Coordinates XYZBCW are required, AUV may be used
* if specified with the coordinates parameter and will
* be mapped one-to-one with the assigned joint.
// non-required coordinates (A,U,V) can be set by using
// the module coordinates parameter
#define REQUIRED_COORDINATES "XYZBCW"
#define DEFAULT_PIVOT_LENGTH 250;
#define DEFAULT_X_OFFSET 0;
#define DEFAULT_Y_OFFSET 0;
#include "motion.h"
#include "hal.h"
#include "rtapi.h"
#include "rtapi_math.h"
#include "rtapi_string.h"
#include "rtapi_ctype.h"
#include "kinematics.h"
#include "posemath.h"
#include "switchkins.h"
struct haldata {
hal_float_t *pivot_length;
hal_float_t *x_offset;
hal_float_t *y_offset;
} *haldata;
static int fiveaxis_max_joints;
static PmCartesian s2r(double r, double t, double p) {
// s2r: spherical coordinates to cartesian coordinates
// r = length of vector
// p=phi = angle of vector wrt z axis
// t=theta = angle of vector projected onto xy plane
// (projection length in xy plane is r*sin(p)
PmCartesian c;
t = TO_RAD*t; p = TO_RAD*p; // degrees to radians
c.x = r * sin(p) * cos(t);
c.y = r * sin(p) * sin(t);
c.z = r * cos(p);
return c;
} //s2r()
// assignments of principal joints to axis letters:
// (-1 means not defined (yet))
static int JX = -1;
static int JY = -1;
static int JZ = -1;
static int JA = -1;
static int JB = -1;
static int JC = -1;
static int JU = -1;
static int JV = -1;
static int JW = -1;
static int fiveaxis_KinematicsForward(const double *joints,
EmcPose * pos,
const KINEMATICS_FORWARD_FLAGS * fflags,
KINEMATICS_INVERSE_FLAGS * iflags)
PmCartesian r = s2r(*(haldata->pivot_length) + joints[JW],
joints[JC],
180.0 - joints[JB]);
// AJ Get x and y offset and radians of C axis angle
double c_x = *(haldata->x_offset);
double c_y = *(haldata->y_offset);
double c_r = TO_RAD*joints[JC];
// Note: 'principal' joints are used
pos->tran.x = joints[JX] + r.x + c_x*cos(c_r) + c_y*sin(c_r) - c_x; // AJ add correction for C axis offsets
pos->tran.y = joints[JY] + r.y + c_x*sin(c_r) + c_y*cos(c_r) - c_y; // AJ add correction for C axis offsets
pos->tran.z = joints[JZ] + *(haldata->pivot_length) + r.z;
pos->b = joints[JB];
pos->c = joints[JC];
pos->w = joints[JW];
// optional letters (specify with coordinates module parameter)
pos->a = (JA != -1)? joints[JA] : 0;
pos->u = (JU != -1)? joints[JU] : 0;
pos->v = (JV != -1)? joints[JV] : 0;
return 0;
} //fiveaxis_KinematicsForward()
static int fiveaxis_KinematicsInverse(const EmcPose * pos,
double *joints,
const KINEMATICS_INVERSE_FLAGS * iflags,
KINEMATICS_FORWARD_FLAGS * fflags)
PmCartesian r = s2r(*(haldata->pivot_length) + pos->w,
pos->c,
180.0 - pos->b);
double c_r = TO_RAD*pos->c;
EmcPose P; // computed position
P.tran.x = pos->tran.x - r.x
- c_x*cos(c_r) // AJ - C axis X offset
+ c_y*sin(c_r) // AJ - C axis Y offset
+ c_x; // AJ - offset - for setup tool at workpiece 0 and axis includes offset to 0
P.tran.y = pos->tran.y - r.y
- c_x*sin(c_r) // AJ - C axis x offset
- c_y*cos(c_r) // AJ - C axis y offset
+ c_y; // AJ - offset - for setup tool at workpiece 0 and axis includes offset to 0
P.tran.z = pos->tran.z - *(haldata->pivot_length) - r.z;
P.b = pos->b;
P.c = pos->c;
P.w = pos->w;
P.a = (JA != -1)? pos->a : 0;
P.u = (JU != -1)? pos->u : 0;
P.v = (JV != -1)? pos->v : 0;
// update joints with support for
// multiple-joints per-coordinate letter:
// based on computed position
position_to_mapped_joints(fiveaxis_max_joints,
&P,
joints);
return 0;
} // fiveaxis_kinematicsInverse()
int fiveaxis_KinematicsSetup(const int comp_id,
const char* coordinates,
kparms* kp)
int result=0;
int i,jno;
int axis_idx_for_jno[EMCMOT_MAX_JOINTS];
int minjoints = strlen(kp->required_coordinates);
fiveaxis_max_joints = strlen(coordinates); // allow for dup coords
if (fiveaxis_max_joints > kp->max_joints) {
rtapi_print_msg(RTAPI_MSG_ERR,
"ERROR %s: coordinates=%s requires %d joints, max joints=%d\n",
kp->kinsname,
coordinates,
kp->max_joints);
goto error;
if (map_coordinates_to_jnumbers(coordinates,
kp->max_joints,
kp->allow_duplicates,
axis_idx_for_jno)) {
goto error;
// require all chars in reqd_coordinates (order doesn't matter)
for (i=0; i < minjoints; i++) {
char reqd_char;
reqd_char = *(kp->required_coordinates + i);
if ( !strchr(coordinates,toupper(reqd_char))
&& !strchr(coordinates,tolower(reqd_char)) ) {
"ERROR %s:\nrequired coordinates:%s\n"
"specified coordinates:%s\n",
kp->kinsname, kp->required_coordinates, coordinates);
goto error;
// assign principal joint numbers (first found in coordinates map)
// duplicates are handled by position_to_mapped_joints()
for (jno=0; jno<EMCMOT_MAX_JOINTS; jno++) {
if (axis_idx_for_jno[jno] == 0) {if (JX == -1) JX=jno;}
if (axis_idx_for_jno[jno] == 1) {if (JY == -1) JY=jno;}
if (axis_idx_for_jno[jno] == 2) {if (JZ == -1) JZ=jno;}
if (axis_idx_for_jno[jno] == 3) {if (JA == -1) JA=jno;}
if (axis_idx_for_jno[jno] == 4) {if (JB == -1) JB=jno;}
if (axis_idx_for_jno[jno] == 5) {if (JC == -1) JC=jno;}
if (axis_idx_for_jno[jno] == 6) {if (JU == -1) JU=jno;}
if (axis_idx_for_jno[jno] == 7) {if (JV == -1) JV=jno;}
if (axis_idx_for_jno[jno] == 8) {if (JW == -1) JW=jno;}
haldata = hal_malloc(sizeof(struct haldata));
result = hal_pin_float_newf(HAL_IN,&;(haldata->pivot_length), comp_id,
"%s.pivot-length",kp->halprefix);
result += hal_pin_float_newf(HAL_IN,&;(haldata->x_offset), comp_id, // AJ - get x offset
"%s.x-offset",kp->halprefix);
result += hal_pin_float_newf(HAL_IN,&;(haldata->y_offset), comp_id, // AJ - get Y offset
"%s.y-offset",kp->halprefix);
if(result < 0) goto error;
// *haldata->pivot_length = DEFAULT_PIVOT_LENGTH;
// *haldata->x_offset = DEFAULT_X_OFFSET;
// *haldata->y_offset = DEFAULT_Y_OFFSET;
rtapi_print("Kinematics Module %s\n",__FILE__);
rtapi_print(" module name = %s\n"
" coordinates = %s Requires: [KINS]JOINTS>=%d\n"
" sparm = %s\n",
kp->kinsname,
coordinates,fiveaxis_max_joints,
kp->sparm?kp->sparm:"NOTSPECIFIED");
rtapi_print(" default pivot-length = %.3f\n",*haldata->pivot_length);
rtapi_print(" default x-offset = %.3f\n",*haldata->x_offset); // AJ
rtapi_print(" default y-offset = %.3f\n",*haldata->y_offset); // AJ
return 0;
error:
return -1;
} // fiveaxis_KinematicsSetup()
int switchkinsSetup(kparms* kp,
KS* kset0, KS* kset1, KS* kset2,
KF* kfwd0, KF* kfwd1, KF* kfwd2,
KI* kinv0, KI* kinv1, KI* kinv2
kp->kinsname = "5axiskins"; // !!! must agree with filename
kp->halprefix = "5axiskins"; // hal pin names
kp->required_coordinates = REQUIRED_COORDINATES;
kp->allow_duplicates = 1;
kp->max_joints = EMCMOT_MAX_JOINTS;
if (kp->sparm && strstr(kp->sparm,"identityfirst")) {
rtapi_print("\n!!! switchkins-type 0 is IDENTITY\n");
*kset0 = identityKinematicsSetup;
*kfwd0 = identityKinematicsForward;
*kinv0 = identityKinematicsInverse;
*kset1 = fiveaxis_KinematicsSetup;
*kfwd1 = fiveaxis_KinematicsForward;
*kinv1 = fiveaxis_KinematicsInverse;
} else {
rtapi_print("\n!!! switchkins-type 0 is %s\n",kp->kinsname);
*kset0 = fiveaxis_KinematicsSetup;
*kfwd0 = fiveaxis_KinematicsForward;
*kinv0 = fiveaxis_KinematicsInverse;
*kset1 = identityKinematicsSetup;
*kfwd1 = identityKinematicsForward;
*kinv1 = identityKinematicsInverse;
*kset2 = userkKinematicsSetup;
*kfwd2 = userkKinematicsForward;
*kinv2 = userkKinematicsInverse;
return 0;
} // switchkinsSetup()
second issue.
Andrew
* Author:
* System: Linux
* Notes:
* wrt z axis
* kinematics.
#include "motion.h"
#include "hal.h"
#include "rtapi.h"
struct haldata {
} *haldata;
PmCartesian c;
c.z = r * cos(p);
return c;
} //s2r()
static int JX = -1;
static int JY = -1;
static int JZ = -1;
static int JA = -1;
static int JB = -1;
static int JC = -1;
static int JU = -1;
static int JV = -1;
static int JW = -1;
EmcPose * pos,
joints[JC],
return 0;
double *joints,
pos->c,
180.0 - pos->b);
P.b = pos->b;
P.c = pos->c;
P.w = pos->w;
&P,
joints);
return 0;
kparms* kp)
int result=0;
int i,jno;
kp->kinsname,
coordinates,
kp->max_joints);
goto error;
kp->max_joints,
goto error;
char reqd_char;
goto error;
" sparm = %s\n",
kp->kinsname,
return 0;
error:
return -1;
} else {
return 0;
Last edit: 26 Jan 2022 09:30 by alj333.
- alj333
26 Jan 2022 15:10 #233175
by alj333
Found the problems.
a small error in the forward kinematics maths, mixed one + / -
the second was speed mismatch on the axis velocities with the bench test setup.
ready to install on the real machine next...
