Native cam lathe threading problem
- rohit269
15 Jan 2022 04:45 #231859
by rohit269
Native cam lathe threading problem was created by rohit269
Sir,
Native cam 0.14b version always cutting thread with front taper I am already trying none and exit taper option but the problem not solve with problem threading repair not possible.
Please tell how to solve this problem.
- Thank you received: 4652
09 Feb 2022 19:20 #234407
Replied by andypugh on topic Native cam lathe threading problem
What G76 command is generated? You could hand-edit the G-code to remove the entry taper.
(Not the best of answers, I know)
09 Feb 2022 19:22 #234408
Or: If you _never_ want taper, it would be easy to edit the NativeCAM threading.ngc file on your machine by deleting the taper entries in the (single) G76 line.
github.com/FernV/NativeCAM/blob/master/l...he/threading.ngc#L96
- rohit269
09 Feb 2022 20:42 #234423
by rohit269
Replied by rohit269 on topic Native cam lathe threading problem
Sir, many many thanks for your reply
Time to create page: 0.101 seconds
