LinuxCNC terminated with an error
16 Jan 2022 12:04 #232005 by IvanSvistunov98
LinuxCNC terminated with an error was created by IvanSvistunov98
Не запускается LinuxCNC после настройки в Stepper Configuration Wizard. Буду благодарен, если кто-нибудь поможет решить проблему. Тест ошибки:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/ivan/linuxcnc/configs/IS1'
Machine configuration file is 'IS1.ini'
INIFILE=/home/ivan/linuxcnc/configs/IS1/IS1.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./IS1.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
waiting for s.joints<0>, s.kinematics_type<0>
Timeout, trying kill -9
Debug file information:
cannot gain I/O privileges - forgot 'sudo make setuid'?
Note: Using POSIX non-realtime
note: MAXV max: 50.000 units/sec 3000.000 units/min
note: LJOG max: 50.000 units/sec 3000.000 units/min
note: LJOG default: 5.000 units/sec 300.000 units/min
Waiting for component 'inihal' to become ready........................................A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
......1876
1903
<commandline>:0: milltask exited without becoming ready
Stopping realtime threads
Unloading hal components
Waited 3 seconds for master. giving up.
stepgen: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hal_parport: not loaded
motmod: not loaded
trivkins: not loaded
<commandline>:0: unloadrt failed
16 Jan 2022 21:46 #232068 by cmorley
Replied by cmorley on topic LinuxCNC terminated with an error
I assume this is a compiled version of linuxcnc?
The text mansions forgetting to issue 'sudo make setuid' after compiling.
Did you so this?
16 Jan 2022 22:17 #232075 by tommylight
Replied by tommylight on topic LinuxCNC terminated with an error
Also not using RT kernel so machine control will not work, only sim.
You need RT-Preempt or RTAI kernel to control machines.
17 Jan 2022 12:46 #232112 by IvanSvistunov98
Replied by IvanSvistunov98 on topic LinuxCNC terminated with an error
Я установил LinuxCNC 2.7.14 Debian 7 Wheezy вместо LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO. Все работает. Спасибо!
02 May 2025 20:07 #327540 by xlordofpainx
Replied by xlordofpainx on topic LinuxCNC terminated with an error
Hey, i have no idea what this means. I can tell you that I downloaded the linux cnc from here linuxcnc.org/downloads/ 2025 version, I made a bootable flash drive and installed it like this, initially I was using only the USB but then I installed it properly and it's the only thing on this PC.
could you tell me what I should do from here?
02 May 2025 20:09 #327541 by xlordofpainx
i tried typing sudo make setuid but u got make:: *** No rule to make target setuid. Stop
02 May 2025 20:32 #327546 by PCW
Replied by PCW on topic LinuxCNC terminated with an error
What are you trying to make?
The LinuxCNC ISO needs no compiling of executables.
02 May 2025 21:22 #327553 by xlordofpainx
I am trying to get my machine to run for the first time on a new PC here is my post: www.forum.linuxcnc.org/38-general-linuxc...inated-with-an-error
I can ping the mesa, I can run the motors during pnc conf, but I can't start the launch after that. Thanks in advance
Time to create page: 0.183 seconds
