error message "joint 1 amp fault"
- sibelius
- Visitor
18 Jan 2022 11:15 #232264
by sibelius
error message "joint 1 amp fault" was created by sibelius
Good evening everybody
I am experiencing a problem with my machine.
Today I turn the machine on and while I was homing I heard a screeching noise and soon after the message "joint 1 amp fault"
So the first thing I did was to check my Y axis motor (I have two motor that operate in this direction; Y ands A).
I turn the machine off to free the limit switch manually.
Next step was to power the machine on again and check the motor and what I observed was that the motor was not lock but the shaft could be turn without effort.
My first thought was the driver or the motor failure.
I swap the Y drive with the Z drive and the Y motor represent with the same issue so my conclusion is: the drive is ok.
I swap the Y motor coil cable and the encoder Y cable with the A motor coil cable and the A encoder cable and at this time the problem appear on the A motor and not in the Y motor so my conclusion are that the motor is ok.
At this point I start to think that the problem should be along the Y line.
I have tried to check for current continuity and I was not able to find any loose or interrupted cable along the Y line.
I tested the Y cable for the coil and the encoder and they seems ok; the power supply seems fine.
Any help would be greatly appreciated.
Thanks in advance
V.
Thanks in advance
V.
- Jake
- Thank you received: 10
18 Jan 2022 16:39 #232297
by Jake
Replied by Jake on topic error message "joint 1 amp fault"
Are you actually seeing the "joint 1 amp fault" in HAL does it state true or false (i do not know how your setup) Do your other joints state differently than joint 1 ?
My amps on my machines open the fault contact in a fault condition, which in my case the input pin will be high for a fault condition so an open contact at the drive/amp or an open wire will tell the controller that there is a fault with the amp/drive on that axis.
Do you have any light indications on the amp/drives ?
What is HAL telling you for AXIS 1 and the others for "AMP FAULT" ?
Do you have individual amp enable, or are your amps individually protected fuse/breaker ?
Have you tried to jumper out the amp fault contact on the amp itself to validate the circuit and to the controller?
The following user(s) said Thank You: sibelius
- Thank you received: 4145
18 Jan 2022 20:23 #232330
Replied by rodw on topic error message "joint 1 amp fault"
You have not told us what drives you are using. Stepper/Servo /Make/Model?
Consult your drive documentation for what can cause a fault signal.
If the drive makes a screeching error, to me that implies a mechanical fault and the motor or rail siezed (happened to me the other day) or a misconfiguration error (accelleration or velocity too fast)
But if there is no holding torque and it works on another it suggests a wiring fault or failed drive/amp.
Your tests indicate a wiring fault but i would make sure I tested a different drive/amp on the Y axis to see its not the drive/amp.
- sibelius
- Visitor
19 Jan 2022 06:33 #232403
by sibelius
Replied by sibelius on topic error message "joint 1 amp fault"
Hi everybody
Thanks Jake and Mr Rod, you can see attached my Chinese step drivers.
I finally find the problem.
It was a bad soldering on the 4 pin connector for the Y axes; I just resold and now is ok.
I notice that sometimes when I am in the middle of a tool change and almost always when I stop a program to restart from a certain line I get a message like" probe activated before probe touching" and the machine froze in that position.
The message is not exactly that, I just do not remember;
This happened after the second measure on the same tool; My macro touch ones at a certain speed and than again at a lower speed.
I attached also my tool change macro.
My electronics is very badly done, I am lazy and anxious to see the router going but at some stage I need to rewire everything also because it takes a huge amount of time when something like this happen.
Thanks again to both of you for your precious help.
Obliged.
V.
Obliged.
V.
Time to create page: 0.087 seconds
