tool orientation display for 4 axis programs?
- Eyecon
- Thank you received: 17
22 Jan 2022 14:48 #232787
by Eyecon
tool orientation display for 4 axis programs? was created by Eyecon
Is there a way to get 4 axis program tool paths to display correctly in gmoccapy? currently when I load a 4 axis program it seems to flatten the moves around my A axis. Same thing happens when jogging the A axis, the tool doesn't rotate, only the DRO changes.
- Thank you received: 2164
22 Jan 2022 15:48 #232791
Replied by Aciera on topic tool orientation display for 4 axis programs?
can you post your .ini file please?
- Eyecon
22 Jan 2022 15:56 #232792
by Eyecon
Replied by Eyecon on topic tool orientation display for 4 axis programs?
Will do but I tried the Geometry=xyza parameter and it doesn’t seem to make any difference. In fact, none of the gmoccapy sim files that ship with 2.8 seem to be able to display tool orientation so this is not specific to my setup. The only example I could find that shows the tool rotating is the “Axis wrapped rotary”
22 Jan 2022 16:03 #232793
Have you set
[TRAJ]
COORDINATES = XYZA
[TRAJ]
COORDINATES = XYZA
