Linux to rs232 controller?
- Thank you received: 7465
24 Jan 2022 17:07 #232981
Replied by tommylight on topic Linux to rs232 controller?
If you do decide to retrofit, have a read through this, it is for Mesa 7i77 so almost everything is the same, save for some pin names for outputs:
- ron456
24 Jan 2022 19:57 #233002
by ron456
Replied by ron456 on topic Linux to rs232 controller?
WOW that is awesome. Thank You.
24 Jan 2022 22:27 #233021
You are welcomed, always.
That's a first, no one was WOW-ed by it till now !WOW that is awesome. Thank You.
- ron456
25 Jan 2022 01:30 #233031
by ron456
Yep. Not everyone gets that excited about retrofitting a cnc, but think it's pretty darn cool. How did your project end up? Any other pointers you want to give about setting it up with the Mesa card would be appreciated. As you can tell this will be my first retrofit. Thanks
25 Jan 2022 13:16 #233061
That project is in use daily from when i finished it at a local factory.
The only issue i had with it is when the PC decided to go belly up.
BTW, that machine is made for milling thin aluminium, but it is used to mill 6mm thick metal, always, and still working.
Time to create page: 4.501 seconds
