Correct stepconf settings for chinese 3040 cnc
26 Jan 2022 03:53 - 26 Jan 2022 04:00 #233145 by RJ11
Just adding this here so google will pick it up for future searches.  That's why the subject is so weird sounding.  For some reason idk why but nobody has the right settings on these things.  The correct settings for X, Y & Z axis are:
200 steps per rotation -> all cheap chinese steppers are 200
8 microsteps -> aka the stepper driver is set to 1/8th stepping (it can do up to 1/16th supposedly)
4mm per rotation -> the ball screw has a 2mm thread but has a double lead so it moves 4mm per rotation
I have tested this and measured it and when you tell it to move 100mm it moves 100mm
This is the type of machine I'm talking about: czhdmotor.en.made-in-china.com/product/W...graving-Machine.html
Last edit: 26 Jan 2022 04:00 by RJ11.
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
26 Jan 2022 04:03 #233146 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Correct stepconf settings for chinese 3040 cnc
Ball screw or Trapezoidal screw ?
Good work anyways.
26 Jan 2022 16:08 - 26 Jan 2022 16:13 #233188 by RJ11
The one I tested was trapezoidal
Last edit: 26 Jan 2022 16:13 by RJ11.
Time to create page: 0.127 seconds
