- Thank you received: 20
Pendant - xhc-hb04 - Jog increments options change
- eriksalo
- Topic Author
4 years 8 months ago #233925
by eriksalo
Pendant - xhc-hb04 - Jog increments options change was created by eriksalo
I have an xhc-hb04 pendant and it's terrific. I use it every time I use my milling machine.
One thing that I don't like about it is when jogging, there are 4 step options: 1, 5, 10 and 20 thousandths of an inch.
The problem for me is sometimes I accidentally select "20 thousandths" when I really wanted to go down to "1 thousandth." I've done this twice and ruined my probe tip.
How do I recompile the code so that it only cycles through the three increments that I want (1, 5, 10) and not through the standard four (1, 5 , 10, 20)?
Thanks in advance
Thanks in advance
4 years 8 months ago #236044
Replied by andypugh on topic Pendant - xhc-hb04 - Jog increments options change
There are a number of stepsize sequences, but none match what you want:
github.com/LinuxCNC/linuxcnc/blob/2e75b0...omps/xhc-hb04.cc#L92
You could edit that part of the code, then (in theory) recompile.
There is a separate makefile for the hxc-whb04b-6 but that doesn't sound like what you have. I feel that would make compiling it outside of the LinuxCNC source tree easier.
I have never tried compiling just a single C++ component, so can't help further.
Time to create page: 0.042 seconds
