How to move JOINT outside of AXIS limit from ocode and from python?
07 Feb 2022 17:47 #234263 by alkabal
Hello
I have setup my machine like that :
[AXIS_Y]
MAX_VELOCITY = 70
MAX_ACCELERATION = 200
MIN_LIMIT = -332.11
MAX_LIMIT = 0.11
[JOINT_1]
AXIS = Y
MIN_LIMIT = -332.11
MAX_LIMIT = 12.11
HOME = 0
HOME_OFFSET = 13
I like to allow the possibility to automatically move from ocode and from python to the [JOINT_1]MAX_LIMIT (used for allow to move to the tool_setter position)
I want to keep the usage of  [AXIS_Y]MAX_LIMIT for all the regular limit stuff
At this point i do not really found the good way.
Br
07 Feb 2022 19:24 - 07 Feb 2022 23:09 #234275 by alkabal
At the end i think about eoffset can be a possible solution
Edit i will think that custom Mcode are a better option
Last edit: 07 Feb 2022 23:09 by alkabal.
