Hal components count & addf
- Benb
- Thank you received: 61
07 Feb 2022 20:52 - 07 Feb 2022 20:53 #234288
by Benb
Hal components count & addf was created by Benb
I noticed that the new Hal configurations no longer require a component count i.e., loadrt pid 5 … that is a great progress.
How about doing away with thread functions ‘addf’ since most of the configurations are now connected only to servo-thread and the odd ones can be overed manually?
Ben
Ben
Last edit: 07 Feb 2022 20:53 by Benb.
- Thank you received: 2175
08 Feb 2022 06:43 #234328
Replied by cmorley on topic Hal components count & addf
Are you referring to allowing NAMES as well as COUNT on more components?
i don't believe COUNTS was removed.
addf is probably not going to disappear as it allows you to select order of component running as well as which thread speed it uses.
Time to create page: 0.309 seconds
