Recommendations on next step.
- Thank you received: 7468
12 Feb 2022 21:33 #234661
Replied by tommylight on topic Recommendations on next step.
Did you test upping the voltage on the power supply?
- Cutter07
12 Feb 2022 23:43 #234667
by Cutter07
Replied by Cutter07 on topic Recommendations on next step.
No not yet. I have had a quick look and can see where I have to do it, but I have to get some work done around the house first. I have it planned for an afternoon job.
- Cutter07
13 Feb 2022 05:27 #234670
by Cutter07
OK....... With the power supply turned up to 55.5 VDC best I could get was 70 inches per minute. Above this it starts to stall.
I was looking into the LAM steppers but there don't appear to be any distributors in Australia, that I can find. I did come across another sort.....Cool Muscle CM1 Steppers these look neat and operate on closed loop. HERE
I had a quick look at the MESA website. Thats another level of confusion for me to learn there. Would I be correct in saying that the high impedance in the steppers I have plus the way I am driving it are the primary causes of the issues I am facing?
Kind Regards
Kind Regards
- Thank you received: 4145
14 Feb 2022 11:30 #234803
The Aussie Lam Technologies distributor is
Ron Nollet
Mobile 0407804712
Replied by rodw on topic Recommendations on next step.
Ron Nollet
Mobile 0407804712
14 Feb 2022 11:46 - 14 Feb 2022 11:48 #234805
Actually, when I look at your motors. I have a pair of the same motors. You don't say what method you've wired them up.
You have to use them in bipolar parallel mode or torque and performance will be very disappointing.
Any other wiring method is basically useless performance wise.
I had to increase my power supply amps to run them from 7 amp to 10 amp because of the current requirement.
But then they performed very well on 48 volts
Last edit: 14 Feb 2022 11:48 by rodw.
- Cutter07
16 Feb 2022 02:26 #234998
by Cutter07
Hi Rod,
I will check on this and report back. In bipolar parallel what speed could you achieve. If I could get close to 100 inches per minute, then I would be happy for the prototype testing etc.
16 Feb 2022 03:09 #235003
My speeds are not relevant really as it was a rack and pinion plasma machine but I could easilly get 750 RPM out of them. I think my rapids were about 20 metres/min
- Cutter07
16 Feb 2022 06:28 #235012
by Cutter07
Afternoon Everyone.
So Rod, I have looked at mine and they are wired in Bipolar Parallel, so I am not sure what the issue is, and why I cannot get a similar RPM.
Ron Nollet - Does he have a website? I will reach out to him this week.
- Clive S
- Thank you received: 486
16 Feb 2022 09:19 #235020
by Clive S
Replied by Clive S on topic Recommendations on next step.
As I said in a previous post. I think Tommy has said the same.
Your link:- www.omc-stepperonline.com/digital-steppe...34-motor-dm860t.html
You could do with upping the voltage to the drives to 65v AC or 95V DC
16 Feb 2022 10:20 #235027
Ring Ron. he is a one man band.
Time to create page: 0.129 seconds
