You don't buy steppers or drives capable of 3000 rpm from steppers on line and you don't run those speeds with a parallel port and software step generation.Tommylight how do you find the Stepper Motors at 3000 rpm? Is there much vibration? I notice that I have a lot of vibration with the current steppers .
Again thanks for your times.
