Jak sprzężyć enconder i RS485
- jarcysgru
- Thank you received: 6
Gdy mam ustawioną konfigurację po przez RS485 i podłączony enconder i włączę gwintowanie noż mi nie trafia dopiero gdy wyłącze sterowanie RS485 i załącze obroty recznie na falowniku robi mi poprawnie gwint.
- Thank you received: 2164
www.deepl.com
Just to be clear, English is also not my native language so I'm not trying to be an ass, just getting tired of running questions through translators.
Translation:
Hi I made enconder( phase A phase B and INDEX) which works only when I switch on rotation manually from inverter, I need to couple(set) it with RS 485 please advise me how to set it up in linuxcnc.
When I have set configuration via RS485 and connected enconder and I turn on threading the knife is not working for me only when I turn off RS485 control and turn on rotation manually on inverter it is working correctly.
Translated with www.DeepL.com/Translator (free version)
- bibiheck
ok i'll look into it thanksYou might want to add a translation of your text in English by using an online translator. This increases chances of it being answered.
www.deepl.com slope game
Translation:Hi I made enconder( phase A phase B and INDEX) which works only when I switch on rotation manually from inverter, I need to couple(set) it with RS 485 please advise me how to set it up in linuxcnc.
