What drives?
Can you switch the X motor to another drive?
Things to keep in mind:
-if a stepper motor is opened and the rotor pulled out = dead motor due to demagnetization,
-if at any time in it's life the motor has been driven with to much current, same thing as above, dead or very weak,
-if metal dust has gotten inside the motor or it was stored in humid places, rust will cause stalling and/or full block.
- some Gecko drives required step times of 15000, to long since i used them, some 500 !
if none of the above apply, then mechanical issues:
-check if the belts lay properly on the pulley all around it, not just partially,
-check for broken bearings or idlers, they cause intermittent stalls
-check pulleys for sticky dust/debris between teeth
-check for belt skipping
-no springs on belts to keep them tight, at high accelerations they will flex and cause skips
