- Thank you received: 4
VFD Vo 0-10V rpm feedback - Analogue pin flicker
- re_relentlessly
- Topic Author
4 years 8 months ago #235965
by re_relentlessly
VFD Vo 0-10V rpm feedback - Analogue pin flicker was created by re_relentlessly
Hello,
I have a huanyang VFD, linuxcnc 2.8, and Mesa 7i76e, raspberry pi4. I have hooked it up using the Anchluss mesa instructions plus DIY CNC Design - Build a better CNC router
And i am now trying to get the Vo analogue output of the vfd ( which reports 0-10 corresponding to spindle rpm) connected to linuxcnc.
I have the Vo output connected to analogue pin 0 of the mesa board (TB6 pin 1), and i have the vfd ACM connected to ground of the power supply (same psu that powers the mesa). A multimeter connected between Field power ground and TB6 pin 1 shows the correct analogue voltage that matches the VFD output on Vo. But (after enabling reading of analogue pins via changing serial 0xxxx to 01xxxx) the Analogue input reported by linuxcnc in both halshow and the halscope (see attached screenshot) just jumps around between 0 volts and ~9.8 volts with voltages in between as well. Clearly i have something wired incorrectly, but for the life of me I cannot figure it out. I tried verifying the analogue inputs by connecting field power +24v to tb6 pin 2 ( analogue 01) and it reports 24.0 correctly.
- Thank you received: 3485
4 years 8 months ago #235967
Replied by PCW on topic VFD Vo 0-10V rpm feedback - Analogue pin flicker
Possibly the signal is very noisy (not unexpected from a VFD)
so a RC filter might be in order
- re_relentlessly
- Topic Author
4 years 8 months ago #235968
by re_relentlessly
Replied by re_relentlessly on topic VFD Vo 0-10V rpm feedback - Analogue pin flicker
so i checked with the multimeter Hz setting and it reports 1.3Khz between Vo and ACM. So i am thinking you are correct (noisy)
so something like
# spindle speed display
addf lowpass.1 servo-thread
net rawSpindleRPM hm2_7i76e.0.7i76.0.0.analogin0 => lowpass.1.in
setp lowpass.1.gain 0.02
net spindle-revs <= lowpass.1.out
it would also seem that the above is missing the basic math to convert the 0-10v signal to rpms
( hm2_7i76e.0.7i76.0.0.analogin0 / maxVoltage) * MaxRPM = ActualRPM
if there any way to perform such math?
so something like
4 years 8 months ago #235975
I would use a RC filter at the 7I76E input
- re_relentlessly
- Topic Author
4 years 8 months ago #235977
by re_relentlessly
I am sorry for all the questions, but I am new to most of this. Could you please clarify what you mean by "RC filter at the input".
A hardware low pass filter?
or just a different configuration of the software filter example i posted?
4 years 8 months ago #235980
Yes, ahardware filter, since there is so much noise
and maybe even negative peaks which would not register
and cause errors if filtered in LinuxCNC
A say 1 K resistor and a 10 uf cap would be a good start
- re_relentlessly
- Topic Author
4 years 8 months ago #236073
by re_relentlessly
So that appears to have worked. I will have to order a 10uF cap since the only thing i had on hand was 100uF (which is what i tested with). The value reported in linuxcnc still flickers a little bit every once in a while (2-5second interval) and the value is a little 0.2 volts lower than what is being output from Vo (measured via dmm). probably have to just compensate by offsetting the value, or attempt to tweak something in the VFD.
I still have 1 question. How do i feed the analogue voltage to linuxcnc to actually use it a the rpm display?
pyvcp_options.hal
net spindle-vel-cmd-rpm-abs => pyvcp.spindle-speed
so i guess i just need to connect it to the pin, as in
net spindle-vel-cmd-rpm-abs <= hm2_7i76e.0.7i76.0.0.analogin0
but that won't do the basic math to translate the 0-10v signal into 0-24000 rpm
pyvcp_options.hal
4 years 8 months ago #236077
If this is for display you would not connect it to spindle-vel-cmd-rpm-abs
as that is the commanded speed from LinuxCNC
You should be able to scale the analog value using the
hm2_7i76e.0.7i76.0.0.analogin0-scalemax parameter
- re_relentlessly
- Topic Author
4 years 7 months ago #237164
by re_relentlessly
Thanks again for all your help. I have now settled on 68uF capacitor (no flicker, but as low a value as possible to keep the responsiveness high (how fast it responds to the VFD pin changing voltage))
I used scalemax to get the scale mostly correct, but due to the RC filter the voltage output of the filter is lower than the voltage on the vfd's pin. I attempted to further correct this by scalemax, but it doesn't work. Since the difference between the rc filters output voltage and the vfd's pin voltage is not constant across the 0-10v range. I guess I need some complex curve based offset?
Is there any way to correct this non linear offset?
4 years 7 months ago #237169
Replied by tommylight on topic VFD Vo 0-10V rpm feedback - Analogue pin flicker
This should do:
linuxcnc.org/docs/2.8/html/man/man9/lincurve.9.html
Time to create page: 0.065 seconds
