LINUXCNC CANopen
05 Mar 2022 12:23 #236421 by Jose01
LINUXCNC CANopen was created by Jose01
Hello everybody.
I'm new here and I'm interested in applications for retrofit lathes and milling machines using CANopen to control drives and IOs. I saw here information about Ethercat, but the drives I intend to use have CANopen as an interface.
Has anyone done any application with CANopen?
Thanks!!!
05 Mar 2022 13:19 #236429 by db1981
Replied by db1981 on topic LINUXCNC CANopen
There exists Interface Devices from Beckhoff.
EL6751 CAN Open Master,
EL6731 Profibus Master ...
With this devices you can interface to your Bus System through Ethercat.
But the configuration is not the easyst/fastest task...
08 Mar 2022 08:14 #236635 by Jose01
Replied by Jose01 on topic LINUXCNC CANopen
Thank you!!!
I´ll take a look at this module.
Time to create page: 0.250 seconds
