Aligning machine with the stock
- avarakin
05 Mar 2022 19:17 #236446
by avarakin
Aligning machine with the stock was created by avarakin
Total newbie with LCNC here.
I have a CNC router which I am currently running using GRBL with UGS or bCNC.
I mostly cut parts out of plywood and many times I cut parts out of cut offs of irregular shape, so I normally use the following workflow, supported by both bCNC and UGS:
1. Jog to a corner of stock and then align to a corresponding corner of g-code by clicking on corresponding point in g-code preview
2. Confirm that my gcode program will not go beyond boundaries of the stock:
- in UGS I use "Contour" feature, which will run the machine along the contour of the g-code program
- in bCNC I use "Move Gantry" feature, where I click on several critical points in g -code preview and machine jogs to those points
I was not able to find similar features in LCNC.
- Thank you received: 7462
05 Mar 2022 21:10 #236452
Replied by tommylight on topic Aligning machine with the stock
I think there is no such feature (well there is but for plasma), but that is easily done since LinuxCNC has a wealthy preview, so jog the machine to the material start pint, touch of X and Y, look at the extents on the preview and use MDI or F5 and type F1000 G1 Xnnn Ynnn, where nnn are the extents from the preview in numbers, be it millimeters or inches.
The following user(s) said Thank You: avarakin
- Thank you received: 4648
10 Mar 2022 00:12 #236798
Replied by andypugh on topic Aligning machine with the stock
I can think of fun ways to do this. One way would be to run a Python script that simply runs through the loaded G-code looking for max and min X and Y, then sends a sequence of rapid moves to trace it.
This could relatively easily be started from a hardware or software button (Or MDI command)
For extra fun it would trace the actual external contour, though that would need more elaborate maths.
Are you by any chance an enthusiastic Python programmer?
- avarakin
10 Mar 2022 01:39 #236805
by avarakin
Replied by avarakin on topic Aligning machine with the stock
I am a little bit of Python programmer, so I may try doing something about it if I have time.
Here is my recent Python project: github.com/avarakin/MirrorGenerator
10 Mar 2022 01:47 #236806
In that case, look here:
linuxcnc.org/docs/2.8/html/config/python-interface.html
You can get the path to the currently loaded file with stat.file(), run through it loiking for X and Y moves, then command.mdi() a set of G0 rapid moves to indicate the area.
(once your script works we can tell you how to call it conveniently with a button or MDI comand)
- avarakin
10 Mar 2022 01:58 #236807
by avarakin
I was thinking of a simpler approach: enter into some special mode, where I can move gantry to a point in loaded g code file by clicking on the corresponding point in g code preview window. In my experience it is more convenient and faster approach comparing to tracing the contour.
Time to create page: 0.252 seconds
