Lincurve
- Thank you received: 4652
22 Mar 2022 01:36 #237989
Replied by andypugh on topic Lincurve
Yes, probably. You will either need to add negative X values to the lincurve or, if there is an "abs" somewhere in the dat path, add the lincurve after that point.
- rider-83
- Thank you received: 10
02 Apr 2022 14:52 #239071
by rider-83
Replied by rider-83 on topic Lincurve
ABS did the trick
Time to create page: 0.078 seconds
