7I76 Pin Correlations
- Ivan_The_Red
12 Mar 2022 20:41 - 12 Mar 2022 20:56 #237018
by Ivan_The_Red
7I76 Pin Correlations was created by Ivan_The_Red
Ive looked all over and cant seem to find any documentation that correlates a physical connection to a HAL pin name. Does anybody out there have a complete listing for the Mesa 7i76 to 5I25.
for example on the 7i76
TB3 Pin 2 = hm2_5i25.0.7i76.0.0.output-05
TB3 Pin 3 = hm2_5i25.0.7i76.0.0.output-04
etc. etc.
( I know these are not correct correlations, but just used to convey what im looking for )
Jeff
etc. etc.
Jeff
Last edit: 12 Mar 2022 20:56 by Ivan_The_Red.
- BigJohnT
- Thank you received: 994
12 Mar 2022 20:59 #237020
by BigJohnT
Replied by BigJohnT on topic 7I76 Pin Correlations
You could use my
7i96 Configuration Tool
it has a page for pins and what they are. It will also create your configuration files and flash the card if need be and a whole bunch more cool stuff.
JT
JT
The following user(s) said Thank You: strahlensauger
- Ivan_The_Red
12 Mar 2022 21:39 #237021
by Ivan_The_Red
Replied by Ivan_The_Red on topic 7I76 Pin Correlations
Hey BigJohn,
Strangely i was just on your configurator, it mentioned that it wasnt up to date so i didnt know if i should use it or not. Ill give it a shot and see if i can get that information.If i can ill compile a list and repost here just in case somebody else might need it.
Thanks for the reply, I appreciate it.
- BigJohnT
12 Mar 2022 21:44 - 12 Mar 2022 21:45 #237022
by BigJohnT
Opps you said 7i76 not 7i96, only my 7i92 Configuration tool works with 7i76 and 7i77 daughter cards.
JT
JT
Last edit: 12 Mar 2022 21:45 by BigJohnT.
- BigJohnT
12 Mar 2022 21:46 #237023
by BigJohnT
Which configuration tool were you looking at?
JT
JT
- BigJohnT
12 Mar 2022 21:54 #237026
by BigJohnT
Here is input 0 and input 31 and output 0 and output 15 when connected to a 7i92
JT
net both-limit-joint-0 joint.0.pos-lim-sw-in
net both-limit-joint-0 joint.0.neg-lim-sw-in <= hm2_7i92.0.7i76.0.0.input-00
net lube-level iocontrol.0.lube_level <= hm2_7i92.0.7i76.0.0.input-31
net spindle-on spindle.0.on => hm2_7i92.0.7i76.0.0.output-00
net flood-output iocontrol.0.coolant-flood => hm2_7i92.0.7i76.0.0.output-15JT
- BigJohnT
12 Mar 2022 21:56 #237027
by BigJohnT
- Ivan_The_Red
12 Mar 2022 22:10 #237030
by Ivan_The_Red
I need it for the 7i76 and 5i25 combination
- Thank you received: 7468
12 Mar 2022 22:35 #237036
Replied by tommylight on topic 7I76 Pin Correlations
Make a 7i92/7i76 config, edit the .hal file by replacing all entries of 7i92 with 5i25 by using the "search and replace" feature on all GUI text editors (xed, mousepad, geany, etc), and there is another line near the top that has to be changed from hm2_eth to hm2_pci
- BigJohnT
12 Mar 2022 23:44 - 12 Mar 2022 23:45 #237048
by BigJohnT
And remove the IP address part of the config.
I should make that configuration tool for both 5i25/6i25 and 7i92 as they are almost the same.
JT
JT
Last edit: 12 Mar 2022 23:45 by BigJohnT.
Time to create page: 0.305 seconds
