Post-processor for Rhino Grasshopper
21 Mar 2022 15:10 #237929 by aaron
Hi
I am trying to find a way of cheaply generating g code for my 5 axis router. There is a project called 5axismaker which seems to do the job via Rhino and the Grasshopper plugin.  I am able to make a file full of xyzbc coordinants, but it does not load in LCNC Axis.
Can anyone tell me how or where to get this to work? I imagine I need a post-processor, but my coding skills are none existent.
Thanks for reading
Aaron
  • Moderator
  • Moderator
21 Mar 2022 15:40 #237937 by tommylight
Replied by tommylight on topic Post-processor for Rhino Grasshopper
  .... but it does not load in LCNC Axis.
Why, error report?
21 Mar 2022 20:40 #237954 by aaron
Replied by aaron on topic Post-processor for Rhino Grasshopper
Thanks for reply
Error message reads: Near line 2 of /blaaa /blaaa blaaa /semisphere.ngcBad Character "\173"used
I have attached the code.
Cheers
Aaron
21 Mar 2022 21:05 #237958 by rodw
Replied by rodw on topic Post-processor for Rhino Grasshopper
Not surprising. Line 1 has invalid G code
Delete it.
22 Mar 2022 20:13 #238033 by aaron
I deleted the first line, now I'm getting 'Cannot go G1 with zero feed rate'
22 Mar 2022 21:09 #238037 by rodw
This line?
{0;0;0;0;0}
22 Mar 2022 21:10 #238038 by robertspark
Replied by robertspark on topic Post-processor for Rhino Grasshopper
that is because there is no feedrate in the file.....
Fxxxxx
suspect that is down to your plugin or 5axis post processor
29 Mar 2022 17:58 #238633 by aaron
Thanks for all replies.
So attached is code generated from Rhino and Grasshopper that has a feed rate, but now I am getting the error:
Near line 2
?////?////??///Simisphere with feed rateRhino
Bad Character 'O' used
What bad character O?
How do I go about making a postprocessor to work with this?
Best wishes
29 Mar 2022 21:12 #238658 by MaHa
Replied by MaHa on topic Post-processor for Rhino Grasshopper
The way there are line numbers, it should give an error also. You can use Nxxxx , but not 1.
Most editors show the line number anyway, so it is not really necessary to have them in the program file.
04 Apr 2022 08:15 #239230 by aaron
Oh Okay
Thanks for this
I will give it a go
Time to create page: 0.283 seconds
