Mesa 7i76e stopped working without a known reason
25 Mar 2022 21:43 - 26 Mar 2022 23:12 #238378 by dru
I finally setup my cnc, everything worked fine for some days.
Once the PC said "a new CPU detected" the step gen stopped working. End-stops are working fine but the step generation didn't.
I've replaced the BIOS battery, the pc was a long time without power before I installed it in my CNC, did a fresh install... but still no step generation.
Is my MESA broken?
I've attached the config files.
I'm happy for every help... thank you!
Last edit: 26 Mar 2022 23:12 by BigJohnT. Reason: fix subject
26 Mar 2022 02:25 #238391 by PCW
Step generation may stop if you have a watchdog bite.
Can you check if the watchdog-has-bit pin is true?
(with halshow)
26 Mar 2022 07:53 #238393 by dru
thanks for your response!
hm2_7i76e.0.watchdog.has_bit is FALSE....
26 Mar 2022 14:54 #238402 by PCW
I would check the output voltage levels of the step/dir pins
(first with LinuxCNC not running and then with LinuxCNC
running but not moving.
Measure from STEP- to STEP+ and from DIR- to DIR+
26 Mar 2022 23:29 #238431 by dru
Got 0V measured with a dmm.
Not having any dif probes here...
27 Mar 2022 01:42 - 27 Mar 2022 01:43 #238436 by PCW
Is there 5V on the TB2 and TB3 5V and GND connections?
If you measure 0V between STEPN+ and STEPN-
or DIRN+ and DIRN- and there is 5V between the
5V and GND pins on P2 and P3 connector, this indicates
that the chips driving the STEP/DIR outputs have been
damaged.
Last edit: 27 Mar 2022 01:43 by PCW.
Time to create page: 0.319 seconds
