previous program is loaded
- halhsasimon
28 Mar 2022 22:32 #238558
by halhsasimon
previous program is loaded was created by halhsasimon
Hi All
Advice needed
if the linuxcnc is stopped with an error code then restart the program the previous program is loaded by itself and the current program is deleted.
please advise me to fix this.
Advice needed
- Thank you received: 7468
28 Mar 2022 22:38 #238559
Replied by tommylight on topic previous program is loaded
More information, please.
- halhsasimon
29 Mar 2022 04:29 #238569
by halhsasimon
Replied by halhsasimon on topic previous program is loaded
Thanks for the immediate reply
While I am running the program in Linux cnc lathe, The program is stopped by any error code, for example, the air pressure is too low. then I have to stop the program by stopping the switch that time the previous program is automatically loaded to the control panel and the current program (running program) whatever in the machine has been deleted by itself.
29 Mar 2022 11:43 #238595
More info, please.
What version of LinuxCNC?
What GUI?
What machine and controller?
LinuxCNC does not reload gcode unless it is specifically told to do so, the only thing that does that by default is QtPlasmaC, and it will not do that from an error report of any kind in normal use.
Are you using QtPlasmaC?
Example air pressure, it should not disable the machine, it should invoke a feed hold until the pressure is back to normal.
What GUI?
Time to create page: 0.071 seconds
