Ethernet
29 Mar 2022 17:44 #238631 by SCLCR-2
Ethernet was created by SCLCR-2
Hi to all,
     I am looking at an Emco PC Turn 55 with no controller.
     It has an ethernet cable for it connection.
     It seem to me that I should be able to plug it in to an ethernet port on my computer that it should run without any extra boards.
     How is my logic?
     Thanks.
29 Mar 2022 18:12 - 29 Mar 2022 18:41 #238635 by my1987toyota
Replied by my1987toyota on topic Ethernet
Most of this kind of stuff isn't as simple as plugging it in and the machine install all the required drivers.
Has this machine been converted to linuxcnc with a Mesa card ? if yes then you will need to set up the Ethernet port. If it's still
the original hardware then you will need to follow the machine's manual or hope you can download one off the net.
 Then follow it's instructions.
That said if it doesn't have a control computer you will either need to find one or
a re-fit is in order . A Dell Optiplex 9020 sff with a Mesa 7i76E card are my current favorites.
If the machine is using servo's then the 7i97 would probably be the Mesa card of choice..
Last edit: 29 Mar 2022 18:41 by my1987toyota. Reason: updating info
The following user(s) said Thank You: SCLCR-2
29 Mar 2022 21:07 #238657 by BigJohnT
Replied by BigJohnT on topic Ethernet
The Ethernet connection is probably for the Emco PC Turn 55 Control board and not an Ethernet port.
JT
30 Mar 2022 15:33 #238745 by SCLCR-2
Replied by SCLCR-2 on topic Ethernet
So with my brief research this refit can become a nightmare.
  • Moderator
  • Moderator
30 Mar 2022 17:23 #238755 by tommylight
Replied by tommylight on topic Ethernet
Why????
Did you read that it MIGHT have a Mesa board, meaning it can be ready for use with LinuxCNC?
30 Mar 2022 17:26 #238759 by SCLCR-2
Well no.
  • Moderator
  • Moderator
30 Mar 2022 17:40 #238763 by tommylight
Can you post some pictures of the electronics?
30 Mar 2022 17:44 #238764 by SCLCR-2
No I can not, I do not own this machine as of yet.
30 Mar 2022 22:58 #238846 by rodw
Replied by rodw on topic Ethernet
Some of the earlier EMCOs with 25 pin connector were able to be converted to linuxcnc. Samco aka Skunkworks worked it out. I know its posted on CNCzone, maybe its here on the forum too.
  • Moderator
  • Moderator
30 Mar 2022 23:54 #238853 by tommylight
Search for Skunkworks on this forum turns just a single post!
Google was better, here is a topic with links to another forum, the link does not work but the search function on that forum works, so i do a search for Emco and ... it returned over 60 pages, so i ran out ! :)
forum.linuxcnc.org/30-cnc-machines/27319...n-55-upgrade?start=0
Time to create page: 0.108 seconds
